air dried lumber
Dave
What is a good moisture content for building. I know someone selling air dried lumber, and he said the moisture content is between 8 and 11. Is that low enough? Thanks
air dried lumber
Dave
Re: air dried lumber
Sgian Dubh
That's plenty low enough for indoor artefacts, but possibly 8-10% lower than it perhaps ought to be for building artefacts destined for exterior conditions, although your locality and typical seasonal RH range should be taken into account if you're building for outdoors. Here in the relative cool and humidity of the part of the UK where I live outdoor wooden artefacts typically hover somewhere between about 18% MC to around 25- 28% MC. Slainte.
Dick Coers
I've built beds and shelving units with wood of that moisture level, but cabinets with doors and narrow rails and styles would make me a little nervous. Really inspect the wood for powder post beetle holes. Especially sapwood!
Sgian Dubh
Dick, why does wood at 8-11% MC unsettle you if you were to use it for door rails, stiles, and panels? Wood at that MC is surely well suited to that sort of job? Isn't that MC content pretty much right in the middle of the MC range it is likely to experience in service in a typical contemporary habitable building with decent climate control, insulation, etc? Slainte.
Dick Coers
Maybe it's just an opinion, but I think wood that has been down to 6-8% and then back up to 10-12, behaves differently than wood that has just air dried down to 10-12%.
Sgian Dubh
It does behave differently because of a form of hysteresis relating to how much you can expect wood to expand when it regains moisture after becoming very dry, i.e., it is a little more stable and generally won't revert back to its former size.
But here we're talking about wood in service that will fluctuate between about 6% MC at the low end and perhaps 13- 14% MC at the high end. The effect of hysteresis in this kind of situation can largely be ignored, given that the wood is supposed to be pretty much in the middle of the expected MC range anyway. On top of that people have been building furniture with both air dried wood and kiln dried wood at these sorts of MC contents for a very long time, and even I've been doing it for decades. Here in the UK even kiln dried wood comes out of the kiln at a target MC of 11% ±1-2%, so there's nothing out of the ordinary with building furniture, doors, joinery, etc with wood at this MC.
I believe you're being overly cautious with your advice, and the caution you suggest is unnecessary if the MC of the wood as stated by the originator of the question is correct. Slainte.
The "real" problem with air dried wood
Often times one doesn't know what it really is or whether it is uniform.
1. Moisture meters are subject to error and especially so at the low end.
2. One often has no idea the history of an air dried stack. Could it have been stacked where the top was dry and the bottom near some damp floor. Has it been drying 10 months and the more exposed parts are 12% and some other part 16? Was it dried by someone that knew how to dry lumber. What is the grade? etc.
I would be able to build most anything from lumber at 10% MC, and have many times. Whether it got to this point by regaining form 7% out of the kiln or by air drying from 110% off the saw is largely immaterial. However, if I am using properly manufactured KD lumber I know that every cubic inch of what I bought was at some time dried to less than 7% and if I have not stored it some damp place it it "good to go" for whatever I want to use it for.
For air dried lumber I have to be concerned whether it was properly air dried (did you know that most kinds of drying defects result or initiate in the air drying phase?). I have to be concerned whether it is uniform, etc. I am likely buying from someone that likely knew vastly less about properly drying lumber than the company operating the kiln. More risk and more one needs to know to keep from having problems.
