Sanding log railings
Howard Norman
Fifteen years ago I did a lot of sanding of log railings in this house. Now it is time to do it on some new stuff. At that time the best method that I found was using a foam pad that attached to your hand with a strap and held sandpaper. I had a couple of the pads here and now I can't find either one. The pads that I had were blue in color and probable 1/4 - 3/8" thick. There were special sheets of sandpaper that I bought from the same place that I bought the pads. Now I can't remember who the supplier was, does anyone recall this product?
If you have a better idea in sanding irregular log surfaces I am all ears.
Howard
Re: Sanding log railings
Look up "Sanding Glove"
Keith Newton
I don't know if it was the same, but I saw something like that in an auto parts store a few days ago, in the department where they sell paint and body filler.
I've been away from the shop for over a week, working on my cabin project, and did a similar project over the weekend. For the little loft over the bath at the end of the great-room, I cut down a little Post Oak which had the right size and length of limbs growing straight out for the rail. Then I ripped it down the middle, and stripped the bark. I installed them the way they grew, but offset where the ladder comes up between the halves. The newel post go on up and tie into the cathedral ceiling, which made it a lot stronger than I could have managed by just tying into the light floor framing alone.
Surprisingly, the bark came off pretty easily, for this late in the Summer. We haven't had much rain at that location, and the high has been in the 90s daily. However, I hosed them down the night before stripping, which helped. the thick bark, I usually knock off with a hammer, striking it at about 45º with a 20 oz waffle face hammer. However, the ends of the medullar rays stood out like little knife blades all over the new surface. I normally would just use my random orbit sander with a soft contour pad, but got down here with the sander, but without any disk.
I did have a couple of portable sander belts, and some scrap of heavy cloth belt from the stroke sander, which worked well. I tore the smaller one to open the loop, then used it like a shoe shine rag, then used the other folded to get into the concaves.
Still, the ROS is my tool of choice.
