styrofoam dryout
mike mcnerney
How do you dry out 12" x 24" x 48" white Styrofoam that was used as floats for a dock?
Mike McNerney
styrofoam dryout
mike mcnerney
Mike McNerney
Re: styrofoam dryout
John in NM
I've never heard of styrofoam becoming waterlogged. Dock floats should use a closed cell foam and never need drying.
All I can think is that the foam volume is inadequate for the weight of the dock, or perhaps the wrong (open cell) foam was used. I've never heard of foam "wearing out" in some way that would turn closed cell into open cell, but I guess that might be possible.
That said, the only way to dry foam would be to let it stand a while, maybe in the sun, and let gravity and air movement do the rest. Not much point though, if it will just need to be done again.
I don't have an answer.
I can tell you that EPS or Expanded Polystyrene or bead board will get water logged. I have a friend who sells hot tub covers. New ones are fairly light and he can handle them easily. Old used ones are often several times as heavy and difficult for one man to handle. No scientific proof, but we assume they are soggy and water logged. What else could it be? Wonder if the water is filling the spaces between the beads?
The blue stuff (Styrofoam) and the pink stuff (Foamular) are extruded and do not have the beads.
Try sticking your blocks of foam in the attic for a month or so. Hot and dry with no sunlight/ultraviolet. Might work.
Yonak
EPS is mostly air. That's what gives it good buoyancy. In a perfect world the air is surrounded by skins of plastic (polystyrene) which would keep the interior air tight. There are reasons why the skin could be compromised, including damage to the exterior skin and to the individual cell walls and incomplete adhesion of the individual cells to each other in the manufacturing process. However, just because you put a gash in the side, the entire foam block isn't compromised because each cell is a self-contained air pocket. Over time of being submerged, water forces its way into the many openings and crevices.
There really isn't a quick way to dry out the block as the years of water seepage can put it well into the interior. The best way to dry it is the way to dry anything .. put it in a dry environment or a place where there is moving air or in the sun. Long-term exposure to sun, however, can break down the plastic, even though the plastic, itself, is inert. Don't expect it to dry out fast but oftentimes it's still quite usable for many things even though it's wet.
Bottom Line . .
Buy new float material. The old stuff "might" dry out by next year . . .
ps: Don't pass up the opportunity to recycle all that plastic if your SWH will take it.
Now you've struck a nerve . . .
Yonak
My local trash dump has recycling containers for aluminum, two types of glass, tin cans, paper, cardboard and plastic, but not EPS. The EPS gets buried with the rest of the trash and will be there long after mankind has vanished. Never mind that EPS is mostly air and takes up a lot of space per weight and that it's a plastic, non-biodegradable material which makes it a perfect candidate for recycling. Why won't they provide a recycling bin for EPS ?
Rant over . . .
EPS leaks
Lee Schierer in McKean, PA
If you take a EPS coffee cup and fill it with water, after several days the water will leak through the spaces between the beads.
If it took several years for the floats to get water logged, it will likely take just as long for them to dry out.
You can dissolve an unbelievable amount of EPS in a small amount of lacquer thinner. It also makes a water proof finish for outdoor type projects.
Lee
Usually that means...
John in NM
That it costs more to recycle that produce new - sometimes that also means it takes more energy, meaning more fuel burned to recycle than make new. It may offend our sensibilities, but then reality often does.
Most localities still recycle white paper, in spite of a truckload (as in semi-truckload) being worth only a few dollars to the recycler. Haul that 40 tons more than a mile or two and you've burned more diesel than the load is worth.
Donate it for archery targets, then
Keith Newton
buy float tanks to replace it. It would probably take longer to dry than a log. I built a bunch of docks over 20 years ago with about $200 per slip of foam. It is still floating, which comes to $10 per year for the floatation. That is a cheap expense to write off.
Also, I think the core of engineers, has outlawed it on any waterways in their jurisdiction.
Re: Donate it for archery targets, then
mike mcnerney
I guess I will have to cut it up to much smaller chunks & carry it 200 ' up a hill & take it to the dump.
cheers
Mike
Re: Now you've struck a nerve . . .
pecker
I wish someone would market an inexpensive machine...like a light duty chipper/shredder, that you could feed the Styrofoam into and get packing peanuts out the exhaust chute. All they would need to be is irregular small chunks, and I could use them for packing material, instead of trying to break up large pieces to fit into a garbage bag that weighs almost nothing but goes to the landfill anyway.
Recycling EPS
Yonak
Chopping it up would be a very messy ordeal, to be sure. If you've got a lot of EPS on a regular basis that you want to turn into "peanuts" you could make an assembly with Nichrome wire to cut it into cubes.
