OT Repairing vinyl siding questions
The house I am working on has a gate at the corner of the house. There is a 4 x 4" post sunk in concrete in front of the corner and in contact with it leaving me no room to remove the corner. The corner is one of those vinyl corners and it has been damaged by the gate latch. I have a left over piece of vinyl corner that matches.
I guess I have three options. Remove the post to get access to the vinyl corner and replace if with the spare. (This seems to be tough. the concrete around the base of the post seems pretty massive and it would leave me to figure out how to deal with the gate/door. its a 6' privacy fence.)
I could cut up the corner section I have and notch out the existing corner and make a "cover" for it. Could slip the new piece into the existing corner and hide on side behind the post. This would look OK (?) until some day somebody removes the post exposing the other side of the patch.
I might be able to cut a small patch and glue it over the tear in the corner board. Can you glue vinyl siding? What glue would you use?
Re: OT Repairing vinyl siding questions
I have "pop riveted" Vinyl siding repairs before. I also think I have used the CPC/PVC plumbing cement to splice a corner one time. Can't remember for sure but wouldn't be hard to test the cement on a sample piece.
Bill Spievak
I had a similar problem. My old mentor, 90 plus years old, suggest I cut the post, repair the siding, then repair the post using long 3/4 inch dowels and epoxy from system 3. I did as he suggested, sanded and painted the post and all has been well for three years.
Jack Guzman from Maine
I agree
I would remove the post, fix the vinyl, and then do what is necessary to replace the post. ---Jack
Mike in Suffolk Virginia
Barry,
PVC plumbing glue/cement works well with vinyl siding as it is PVC. Clean joint with the clear PVC cleaner/primer and glue away. I have edge glued the 3/4" vinyl trim boards together with no problems and was unable to break the joint. Got the tip from on here.
Mike in Suffolk now in in Zuni, VA
Gluing vinyl siding - not so hard
Don in STL
This isn't as hard as we may think. I just had my house vinyl sided and found that the installers were using caulking tubes labeled "caulk/adhesive" to caulk all the seams, as well as to strengthen joints. When I inquired about this, I was told that using 100-percent exterior silicone also works.
Re: Gluing vinyl siding - not so hard
I tried gluing some scraps with Plumbing glue for PVC and it appeared to work well.
Glued a piece behind a hole in the siding. I guess a rock was thrown against the siding. Looked like a bullet hole. Sort of buttoned the patch through the hole, Shoved in a plastic bag for "fluff" and glued the back of the siding and the front of the patch. Seems to have worked well. The fluff pressed the patch against the siding. the best thing to do would be to replace the entire siding job, but that ain't happnin.
