OT- Rustoleum Restore
Tom
I was wondering if anyone has used this product? I have an older deck that will be getting new decking in a few years and thought this would be a good "dress-up" in the mean time.
Thanks!
Tom
Thanks!
Re: OT- Rustoleum Restore
John E. in SC
Haven't used it personally, but I have looked at the reviews on Amazon. It's pretty evenly split between good and bad reviews. Most folks comment on it taking a lot of paint to cover, which can make it fairly pricey. May not be worth whatever time it buys you.
I have not used it either, but I am highly skeptical. I stopped at Home Depot and they told me it covers 100 sf per gallon, but requires tow coats, thus fifty sf per gallon. It was $78 for four gallons or about $.40 a square foot.
I doubt it will hold up long. You are only coating the top side. Water will drool around it and soak up from underneath. I am betting the coating will peal off like tape after a while.
So, if its worth the time an effort to get a year (maybe) go for it.
Dave Bair
I used a similar product, Behr Deckover, in June. So far it looks as good as the day it was applied. It's a bit easier than the Rustoleum product in that it goes on thinner and with a standard roller instead of the textured one. It filled cracks quite well and I got three coats (with about a gallon left over) out of the amount recommended for 2 coats. They do insist on at least 2 coats to validate the warranty.
Mike Johnson
I used it on our front porch and, so far, I am very pleased with the results. Of course, it's only been a few months, so I can't yet comment on how long it will last.
Not for a screwed down deck!
Grant in Iowa
Consider how you would remove the deck screws later if and when you decide to replace the decking. The stuff would most certainly prevent screw head access, wouldn't it?
FWIW,
Grant in Iowa
