need a waterborne finish recommendation
I am about ready to finish the ash desk and I am looking for a durable water white finish that will not yellow over time. Many of the waterborne finishes meet this requirement.
I have had some experience with waterborne finish over the years and it has not been favorable. My main complaint is that what I have used has not given me the clear bright luster of a solvent based finish such as lacquer or varnish. However, I realize that much work has been devoted to improving these finishes so maybe there is something out there that will look like lacquer and not be yellow or turn yellow.
Additionally the finish needs to be durable in a desk top application.
Re: need a waterborne finish recommendation
John Veerkamp
I use Minwax Polycrylic Satin. I am now completing a walnut bed that looks great. I use it on lighter woodturnings that I want to stay lighter.
Merle
Take a look at this Target Coatings. I use their product line exclusively. The company president is a really good guy who makes himself available by phone, email and on their forum.
http://targetcoatings.com/products/interior-top-coats/em9000-super-clear-interior-polyurethane.html
http://targetcoatings.com/products/interior-top-coats/em7000hbl-high-build-lacquer.html
Clint Searl
Clint Searl
Bona Mega floor finish or Varathane floor finish.
GolfSteve in Calgary
I've used Target's lacquer several times, but usually on a darker wood where I want a richer tone compared to topcoating a white wood. Target on top of cherry looks great.
Target finish samples:
Gloss (the figured maple board was very brown/yellow to start with, so not a great example of how the finish affects colour). I also rubbed out parts of the plywood board to different glosses. I've never been happy with how the Target rubs out - to me it just looks scratched up. However, the Target polishes to high gloss very well.
Semi-gloss on Baltic plywood:
Gloss Target on cherry
The gloss Target is a bit "plasticy" if applied too thick. If applied too thick (or perhaps too fast) I have also gotten a bluish tint that took years to go away. However if applied fairly thin I am very happy with the finish.
The finish has stood up relatively well on our coffee table, suffering the abuse of a 3 and 6 year old for several years.
On my latest project I applied a thinner finish, and used a final coat of satin Target, and I was very happy with the final finish. No plastic appearance at all.
Target on cherry - first coat of shellac, then dyed gloss Target topcoats, with one final coat of satin gloss.
Jim in Burlington Ont.
Looks great
Jim in River Oaks, Ont.
Hi Steve,
The finishes look great!
BTW, was thinking about you during the terrible flood, I hope you were not effected.
Take care,
Jim
Don Stephan
I've found Jeff Jewitt at homesteadfinishingproducts.com to be completely trustworthy and extremely knowledgeable about how to obtain desired looks with differing methods of application and experience levels.
Jesper, Denmark
Re:Why does it have to be waterborne???
Jesper, Denmark
My experiences with clear water reducible finishes has not been good. Waterbased paints seem to be developed to a point, where they perform well, but not clear finishes.
They all do contain solvents anyway, and some materials, which are not so nice and do not have long enough history to be proven "safe". So, my take is that I will rather deal with the solvent devil that I know, than the co-solvent devil I don't know.
In the auto industry, waterborne primers and color coats are standard, and there have been used either powder coating or waterborne clearcoats. However the trend there is to go back to solvent based clearcoats from a pure performance consideration.
If it has to be waterborne, then I would look towards industrial floor finishes, such as used in gyms or basketball floors.
the answer was provided
If you can recommend a solvent based finish that is water white and one that will stay that way I would be delighted to use it. A yellowing finish on ash will make it look like it has been stained with a yellow dye and that is not a pleasing look.
Re: the answer was provided
paul in AZ
Ash will very slowly yellow no matter what finish is on it.
I have two pieces in my house that I built something like 30 years ago. A cabinet that I oiled and waxed with no other finish is now a rich honey color leaning to amber and a table that I varnished but likely didn't oil is somewhat paler with a more yellowish look. That had to be a solvent varnish.
Jesper, Denmark
Jesper, Denmark
I can't give you a specific product, but suggest you look for an automotive clearcoat repair finish. Intended for light base colors, it would have a very minimum of color impact.
Kneale Brownson
Kneale Brownson
I don't think an automotive finish responds well to the expansion/contraction of wood.
Robin Corell in Atascadero,CA
I use General's HP poly. I use the floods formula and if you leave it a applied it will have a distinct plastic look. to correct this I knock down the gloss with 0000 steel wool and then apply a coat of paste wax.
I use a brush but the finish can be sprayed. Once dry it sands like nitrocellulose. And like all finishes it takes a full month to cure. during the first couple of Weeks you will not be happy with the hardness our abrasion resistance, be patient. Once curred it is exceptionally hard and stretch resistant.
Repairs to the finish don't burn in like lacquer but the blend and disappear just as well.
In a FWW review of h2o finishes a few years ago generals HP poly rated as the most water clear of the batch. It has a slight amber a opposed to a blue tint but you well be hard pressed to see any color.
Robin
General's HP poly
Robin
Re: Clear solvent based finish
Doug Wolf
Hi Bill,
I finished this maple turning in May 2011 with a mixture of 50% Deft sanding sealer and 50% lacquer thinner on the lathe. After a couple weeks I triple buffed with Tripoli, white diamond and carnauba wax and it is still as white as the day I finished it.
