Help save a bear from bugs!!!
Joe Pack
A friend of mine agreed to try to help save a chainsawn bear statue that had been damaged by wood rot and bugs on the legs. This statue is enormous...a good 30" in diameter and 6' + high. He drilled out rotten/bug worked wood from the legs, stabilized the wood and reinforced the legs with steel rods from foot to hip. Structurally, the legs and support should last.
The unsolved problem is that the bear is riddled with bug holes that appear to still be active...fresh sawdust found at the base of the statue after applying stain/sealer. The holes are just slightly smaller than a pencil eraser, slightly oval and are spread from head to toe. Too much work has been put into this carving to ignore the ongoing bug damage. The question is how to eliminate the active critters. Any experience with this? (Bug damage, not bears.)
Re: Help save a bear from bugs!!!
I don't generally like poisons, but you might think about a tent built over it and some appropriate bug bomb set off inside the tent.
Microwaving it would work if you had a big enough microwave...
I dislike using bug bombs.
Tent the bear statue with some heavy duty plastic and duct tape. Leave a small vent hole at the top (quite small - pencil diameter or so). Buy some dry ice (several pounds should work. Place the dry ice in the tent and seal. As the dry ice evaporates, it produces CO2 gas. CO2 gas is heavier than air (molecular weight of 44 versus an average molecular weight of less than 30). The CO2 gas will gradually displace all the air in the tent (it will exit via the vent hole). The bugs will suffocate.
Afterwards use something like Boracare (or a solution of sodium tetraborate in water) and spray.
Bomb it
This calls for chemical warfare. Tent and bug bomb. Get one from a greenhouse if you want to use the "nuclear" option. Alternatively, a high concentration of solvent would work, but with a flammability risk unless you could find chloroform or methylene chloride(an option I use to rid a corn barrel of bugs). If you can find a farm supply that sells methyl bromide that would be dandy to use. It used to be widely used for sterilizing soil but is probably banned now days.
Needless to say, if it kills bugs, in high enough concentration it will be harmful to humans.
My first though was Boracare mentioned by JL above. The problem is the stain/sealer. Boracare will penetrate deeply into the wood, but I think the sealer will interfere. Boracare is a syrupy solution of a borate and glycol. The glycol is more poisonous to us than the borate. The same company (Nissus, I think) makes or markets Timbor and it is a powder mixed in water, but it will be even less effective than Boracare. They use glycol as a penetrant, to care the borate deep into the wood.
I have no experience with dry Ice, but it seems it would work and it would be safe and cheap, harmless, and leave no residual effects. The lack of residual effects could be bad in the sense that there is nothing to keep the bugs from re infesting the piece IF you manage to kill the current crop. They used to tent and gas houses with either methyl bromide or Viacane, both nasty stuff and dangerous, but effective. I think neither has much on going effectiveness.
If its still available another approach would be to insert numerous piece of Impel into the statue. Impel was solid pieces of material designed to "melt" and infuse the wood from the inside out with preservative. Not sure what the chemical was, but it may have been a borate.
Might be time to contact some sort of historical preservationist or someone who restores old wooden ships.
Kill 'em in a kiln
Tom Dunlap
There's likely a commercial kiln around that could cook the bear.
I wonder if a black plastic wrapping might get hot enough to cook it. The catch is that you'd have heat/cool cycles which might not get the interior hot enough for long enough to kill the vermin.
YOu could drill some small diameter holes in varying depths around the bear to tell when each portion is cooked...to well done I think ;)
Tom
a risky plan
If 8/4 lumber gets destroyed if run with a 4/4 kiln schedule imagine what something the size of this bear will do when subjected to temperature/humidity profile used to dry much thinner lumber.
Re: a risky plan
Tom Dunlap
When I lived in the north Dallas area I visited a mill/kiln operation. The owner gave me a nice tour of the whole setup. I asked him about drying whole logs. He said that he'd done a few and it was tricky. Since he didn't have many times to experiment with his drying schedule. Mostly a lot of art with a little science!
Tom
The bugs will be easier to kill than eggs..
Dick Coers
If the insect is an egg laying critter, that is the problem. You will kill the bugs with CO2, pesticide, or other miscc, but those methods will not get into the wood and kill the eggs. Heat is the accepted methods for bringing the entire piece of wood to a point where bugs and eggs are killed.
Sgian Dubh
If you can find someone in your area that operates a Thermo Lignum chamber (or a [presumably] North American equivalent) that method of insect control seems a likely candidate to deal with the infestation, including the bugs, larvae, and eggs. Slainte.
http://www.thermolignum.com/home/
Much better idea
If you don't like dry heat, use steam.
Keith Newton
that is what I would do.
first, I would build a box from insulating foam board, then run a hose from the canning pressure cooker pot, over a propane fish cooker. The steam is just a delivery system, which will end up leaving the wood around 18% MC. You could use a tarp, but will loose more heat to the outside, than gets into the wood.
It needs to get up to about 140º F, all the way through to kill the ones in the middle. If you have one of those meat thermometers with a cable probe, you could drill a close fitting hole into the thickest part, and be able to read the temp from outside.
After it reaches the desired level, leave it wrapped in plastic while it cools, to keep it from drying on the surface while dissipating the heat. the heat will kill eggs larva, and adults. The holes are from the adults leaving to find mates.
After mating, the females lay eggs in cracks, which starts the cycle all over. This is what the borates prevent. Of course, paint or other film finishes do that for your house, so it will work too, so you could caulk all the existing holes with a good matching color, then maintain a good finish to keep them out in the future.
Back to the pressure pot. Mine was for canning jars, but now is dedicated for my steam chamber, so I removed the blowout protection, and tapped it for 1/4" NPT, to run the tubing to the chamber. If you are afraid of what the wife or mom would do, I'll bet you could use a hose clamp over the little stem that sticks up for the weight to sit on, to adapt an automotive heater hose to the box.
Water weighs 8# per gallon, so if you weigh the pot beforehand, you can use a spring scale to lift the pot while it is on the burner, to calculate the rate of evaporation, and prevent boiling it dry.
