table
table
table
ronnie
I need to make a dinning table 54”x 54” I’m thinking of using ¾ oak plywood with a 3” border of oak ¾ or better depending on what I can mill out of what I’ve got, with a ¾ oak apron and use some pine legs that I have that are currently painted white with several coats over the years. I would like to stain the table top with ebony and cover with polyurethane.
I have a few questions:
(1) I don’t have any clamps that will reach 54”, how would be the best way to clamp the table top?
(2) I have not had any success with ebony stain on soft wood even with some type of pre sealer, is there anything I should know before staining oak.
(3) I’m assuming that 4 study legs set in 4 or 5 inches from corners would be sufficient for a 3/4 “ top with the apron glued and screwed , if I’m wrong please correct me.
(40 My wife will make the decision but what color should I paint the legs to go with the ebony top?
Ronnie
Re: table
Re: table
You could use band clamps to clamp the edges. Actually you could use straps like cargo straps. You can buy a four pack of them for less than $20. I would put them across the top rather than around it, or both. It might be tedious to cut miters at the corners. You could put two opposite sides on, flush with the edges of the plywood and let the other two rum past. IE two sides would be forty eight inches long and the other two fifty four inches.
This is a situation where biscuits or a spline might be useful.
You could do two sides at a time with four or five clamps. Pipe clamps would do a good job and making them five or six feet long is no problem, just buy long enough pipe.
Four legs and rails should be strong enough.
You will have to play with the stain on scraps to see what you can get.
Re: table
Re: table
You can make clamps by cutting boards - 1x4s should do it - longer than the length you need by enough to nail on a cleat on each end of each board, with enough room for two wedges, in opposite directions, between one cleat and the table. Set the table on the boards, snug one side up against cleats, then use the wedges to apply pressure
Although...for the design you describe, the other choice is to drill holes through the edging for screws to snug the edging to the ply. The drilling needs care, of course, so the holes and screws are straight into the ply.
Make your edging a little thick, so you can plane it down after you apply it, instead of trying to align it perfectly while you clamp.
Re: table
Re: table
Don Stephan
You might consider an intermediate rail or two running between a pair of aprons to add stiffness to the plywood. Not at all sure how long lasting a pocket screw joint between the apron rails and the legs will be. Glue will not add much strength because the rails will be end grain when butted against the legs. A mortise and tenon joint or even a pair of biscuits with the pocket screws will be stronger. Just my two cents.
Re: table
Re: table
Dick Coers
You'll need more than just butt glue joint for 3" wide rim. Half the glue surface on the side of plywood is end grain, so not much strength from butt joint. Tongue and groove, thick spline, etc..... 3/4" is going to look pretty thin on a table that size. I would use thicker oak for the rim, then cut a rabbet on the solid oak and glue and screw to the plywood. No clamp problems then.
What trouble do you have with the stain? Consider a spray coat of dye to start, then stain.
I'd paint the legs deep burgundy.
Re: table
Re: table
ronnie
Thanks guys,
You've gave me some great ideas,I really like the idea to rabbit the trim I was kind of worried about it being so wide and could have considerable force put on it with a heavy elbow.
Ronnie
