Bunch of new work
Bunch of new work
Bunch of new work
Thomas S Stockton
Hi All
Spent yesterday afternoon catching up with photography, I think I am getting the result I want.
The bubinga pieces started off life as a dining table I made that I was never really happy with, it was to large to fit in our house and there were some functionality issues with it also. It sat around and one day while driving I decided to cut it up and make a counter height table out of part of it and something else out of the rest. When I cut it up I put the extra top on some leg parts and thought it looked like a cool idea for a desk. The stools were made out of new wood and the bars are stainless steel.
The walnut piece is claro walnut, circassion walnut burl and ebony, it was built to hide a printer in the clients office.
The inlay on the desk is ebony, abalone and mother of pearl.
Thanks for looking
Tom
here are two pictures of the table before I took a jigsaw to it.
The table and stool
Bubinga desk
Inlay
Printer cabinet
Re: Bunch of new work
mark valsi
wow indeed !
Robin Corell in Atascadero,CA
Nice work as always. I really like the design and execution on the printer cabinet. that doesn't look like claro, you sure it isn't bastigone?
Picture taking is one of my least favorite tasks. Partly because I have to move everything out of my dining room and convert it to a photo studio. I have the same problem you do, not enough distance to be able to get far enough away to keep the shadows off the sweep. It looks like you have more room on the sides than I do. Did you try bouncing some light onto the back ground to diffuse the shadow? The only one that really needs it is the pix of the desk.
Are the new photos for anything in particular? perhaps a show entry whose deadline is 8/8/?
Robin
Thomas S Stockton
Robin
Printer cabinet is a commission to be delivered on Friday. The panels are burl and the solid had a lot of light streaking in it that toned down pretty quickly after it was milled.
Not sure what I'm doing with the desk and stools/table yet can you fill me in on the show with a deadline of tomorrow.
I need to get a reflector I tried using white foam board but it can only do so much.
I've finally gotten to the point of knowing how I want the pictures to look and all the variations involved.My biggest challenge so far has been getting white balance correct I've tried various tricks for setting it and my cameras flash setting is off from my strobes so I shoot in RAW and correct. Makes a huge difference how a photo looks getting it correct.
I have one light on a wall mounted boom and if I get another and do some easy rearranging I can probably get enough room to use more paper.
Thanks for the tips
Tom
Philip Duffy
Wow, what beautiful work! ! Thanks for sharing. Philip
Love the design of the walnut piece.*****
Beautiful work as always!
Pleasing to admire...questions
Joinery
Table- How is the apron/rail (or whatever this part should be called) attached to those lovely legs? Looks to be a difficult joint.
Printer cabinet- How are satellite cabinets attached to the main cabinet?
The deadline for the American Craft Council shows is today.
I don't really know that much about photography. I learned how to get what I need with a manual film camera and tungston spot lights. It's taken Mr a while to be able to get digital images i'm not embarrassed to share. I don't use flashes or strobes. I'm kind of off that way, I like to see what i'm getting. This makes it really easy for me to set my white balance. I usually use a page from my sketch book as a grey card. And Iplace out where the lights are and since i'm not using the flash on my camera I just bring the camera in close and set the white balance. doing it this way let's me use a mix of a couple of big fluorescent photo lights a well as some cheap little clip on spot lights.
Way back when I took a presentation class in college I was told that sculpture looks most dramatic when lit by a single spot directly overhead. I've found this also holds true for furniture but then you have to add a bit of light to be able to see the legs and to eliminate any confusing shadows.
The wood fir the panels on your printer cabinet is so spectacular and so perfectly book matched I assumed it was veneer. Finding wood like that is amazing and i'm guessing very expensive.
Robin
Re: Pleasing to admire...questions
Thomas S Stockton
Bill
The joints on the desk started out as half lapped and still are on the end pieces which I could reuse , when I cut it down I reassembled the front and back with domino floating tenons.
The printer cabinet bottom and back are each single pieces so the satellites aren't really attached but are part of the whole from the beginning. The picture can probably explain it better and the back and bottom are a similar shape.
Tom
the other table......
Thanks for the detail on the printer cabinet. It is a delight to look at. You have a way of mixing woods, something I am not typically fond of, that turns out pleasing.
The leg joinery question was about the table(?) that was next to the stool. Its top looks interesting. Do you have a picture featuring the top?
Re: the other table......
Thomas S Stockton
Bill
The joinery is fairly straight forward, the rails are cut at 45 degrees with floating tenons holding it together.
Tom
The joy of floating tenons
I wish I had a means of making this joint. They make some joinery problems much easier.
Re: The joy of floating tenons
Jesse Cloud
Easily made with a router and a mortising bit. I make an mdf jig with a slot the width of a guide bushing and sized to the appropriate length, clamp it in place and route the mortise. The tenons are easily made from scrap, you can get the thickness spot on with shallow cuts on the planer. Cut to width and round over the edges to fit the mortise.
I have used these on chairs which take a lot of abuse and show no issues over several years use. Great for compound angle joinery.
