You CAN keep Gorilla Glue from hardening
Keith roberts
I have a bottle of Gorilla Glue that's almost 2 years old. The answer is a simple little product called 2blok .go to 2blok.com to order. This stuff is no hoax.
Keith roberts
Re: You CAN keep Gorilla Glue from hardening
RobbCarr
I can beat you! I have a bottle that is over 4 years old. The trick I learned was to pour about 1/4" of mineral spirits into the container after use, then pour off the mineral spirits before using it.
Tom Dunlap
Can it be reused?
My guess is that the 2blok gets contaminated with whatever is in the tube and it becomes a one-use item.
Or, can the contaminant be picked out and the 2blok used again and again?
cheap alternative?
This product idea suggests that any of the kid toy polymer gels might work.
Like this? *LINK*
Tom Dunlap
Or this stuff:
I don't like Polyeurethane glue
I haven't found anything that glue will do that epoxy or PVA glues won't do equally well or better. And they are both very easy to clean off your skin if you get it on you.
Gave Mine Away
Thought it was great until joints started to fail.
I too go with Epoxy or PVA.
Re: Gave Mine Away
Dave in Bryn Mawr
Why anyone would use this product is a mystery to me.
