Installing SOSS Invisible Hinge
Stephen Kirk
I'm on the last step of a gate leg table, which is to make the stepped mortise to install the hinge. Seems like these have to be really accurate. I'm guessing I should make myself a template or two. Soss will sell me a template for $30 which seems a tad excessive since its just a wooden routing jig.
Has anyone else installed these and found some good tips?
Re: Installing SOSS Invisible Hinge
I always just winged it with a plunge router and a guide fence. The installation jig would most likely have two separate router bushing templates -- one for the full-length shallow groove and the other for the deeper groove in the middle -- and you'd need a separate set of templates for each size of hinge. If you have a lot of hinges to mount, a jig would be helpful.
Hikmet c. Sakman
Hi Ellis,
I use top bearing router bit in a jig for hinges wide enough to use router bits with top bearing, the middle section can be done afterwards with forstner bit and chisel.
Chico...
Gene Gauss
I used a doweling jig and brad point bit with a drill stop, being careful to accurately locate the holes on either end so that it was a snug fit for the hinge. Moving the jig toward the center of the cutout and drilling overlapping holes, deeper in the center section as necessary, and finishing it with a sharp 3/8" chisel did it quite well. Getting the depth right is important. I did go a little deep on a couple, but washers under the hinge to bring it level with the surface fixed that ok. Tedious but effective.
