Joint issue on the desk- dovetail something arced
Curtis Buchannan, the Windsor chair person, has a provocative definition of "professional". In his mind you become professional when you become confident of the result. This skill based definition has merit, compared to the economic based definition often used. By Curtis's definition I will never get there because I add a new construction element to each new thing I build now days and in the case at hand it is a bent lamination stretcher shown in the pictures.
The question is how to orient the dovetail that will tie it to the stretcher? Should it be aligned with the stretcher, or itself? In the first picture I have made a test cut so that the end of the dovetail is parallel to the stretcher. In the second case the end is perpendicular to the tangent of the curved stretcher. While the dovetail will be straightforward to saw, the socket will not. I think the socket in case 1 will be easier to saw and chisel. Maybe there is some possibility I have not considered. Anybody got experience with a joint like this one?
