Plywood question...
Plywood question...
Plywood question...
John in NM
Does anyone know of a multi-ply product, like baltic birch, that is available as 1/4" thick 4x8 sheets? Need 80" length and I'd prefer not to have to splice BB, but it may come to that.
Re: Plywood question...
John Stegall
Appleply. http://www.appleply.com/specifications.php
John
I would love to find a vendor for it...
John in NM
But the only one in my area doesn't take credit cards, and as this project is a favor for my employer, material payment has to be done over the phone by CC. This is turning into such a headache I would turn it down flat if it were a paying job and I had any kind of choice about it >(
The vendor in Albuquerque is long gone, I don't even recognize the name.
It may come down to getting some shop birch at my regular yard and hoping for the best... that will still be better than the junk from HD.
Re: I would love to find a vendor for it...
Bruce, a MN Galoot
Does it need to be a BB kinda thing? How about the 5-ply flooring underlayment?
Jesse Cloud
Hey John,
If the vendor in ABQ you mention is Lumber Products... they were bought out by Rugby Building Supplies. I haven't dealt with them in person, but a friend who has says they are largely the same people working for a new co. which seems to be selling pretty much the same products. Might be worth a phone call (505-924-2270).
Jess
That's my regular yard...
John in NM
I really like those guys, I was very relieved when Rugby bought them out since it was possible Lumber Products would go under otherwise.
The vendor Appleply lists on their site is Southwestern Lumber Sales. Only about a block away from Rugby, but Google maps image shows a big empty yard with an "Available" sign out front :D
I'm planning to call Rugby and ask about other alternatives monday, but I suspect I'll have to go with BB and just deal with the joint.
Do you know if Alpine actually carries Appleply or if it's a special order kind of thing? I've always wanted to get some and see how it compared to baltic birch. For my own use I'd spring for a sheet, but for work I get decidedly un-charitable :D
The project is this...
John in NM
We move astronomical radio receivers around on this cushion bed that goes in a truck. It has tire tubes for cushioning, and the biggest one we have is made of 4 pieces of 48x80 3/4 CDX with a bunch of 2x4's and 4x4's. Thing must weigh 250# and everyone hates it (except the operations manager who made it in his garage :D ).
So I offered to make a light one the last time we had to move that thing, figuring I could make a torsion box with 1/4" faces and probably keep the whole mess well under 100#. Then it became a matter of pride to keep it light, so I really want to use 1/4" instead of 1/2" - and quality rules out anything that will make little cracking noises when stepped on - like the 1/4" fir from Home Depot does, even over a short span.
So that in a nutshell is why I'm hooked on using something like BB. I would probably risk the run of the mill 1/4 CDX or BC or whatever it is, except they tell me that remote payment from HD is impossible (leave it to a bureaucracy to make simple stuff impossible :D )
I may try some shop birch though, I can get that at a real yard that will do a will call CC order and the stuff is glued up dry as I remember, so it will be reasonably flat with none of those little cracks that make the 1/4" from HD so flexy and noisy. Or I may try a 45 scarf on some BB, in a torsion box that would probably hold well.
Somehow this simple task has turned into something worse than making an ugly coffee table for Aunt Edna :D :D :D
William Duffield
Orange Borg used to carry (15 years ago) a product from Paraguay called ParaPly, made from guatambú, Balfourodendron riedelianum. I don't know if they still carry it, and I also noticed that after I had bought and used a lot of it, the quality started to decline significantly. A downside, compared to birch and maple, is that you need to sand and seal the surface, otherwise it tends to fuzz and to pick fibers.
Re: The project is this...
Bruce, a MN Galoot
then you really should check out that underlayment stuff. It's 5-ply plywood, and it doesn't crack when you step on it. It can't, because it goes under vinyl and stuff and that just wouldn't do to make noise under a vinyl floor.
Don Stephan
Here in Cincinnati I've been able to get 1/8" poplar bending plywood. If you could find similar you could at least offset the joints and lay up 1/4" thick skin. Were you planning to use wood strips for the torsion box core? An alternative is three or four pieces of 1" square metal tubing with 1" high density styrofoam between.
I will check that out...
John in NM
It seems to have some good possibilities, thanks!
Where do you get it? Lowes/HD or a specialty supplier?
The core...
John in NM
Plan is to make the core out of strips of pine or plywood. I'm tempted to glue and set with no nails, then I could get really crazy and use 1/4" ply for the ribs too :D
Re: That's my regular yard...
Jesse Cloud
Don't know if Alpine carries apple ply, I do know that I once saw a Lumber Products truck delivering plywood to Alpine for what thats worth. Might give them a call, though.
Re: Marine Ply
Tom
Marine ply is another option. High quality like BB, but it is lighter, or heavier, and has a different colour pallet.
Re: I believe both Lowe's & HDepot carry it
Kurt
Some Lowes carry apply ply but not all; check their web site to see which stores carry it. It sorta looks like partial sheets but it might be worth checking at a store, they might be able to order full sheets.
