Looking For Rocking Chair Plans...
Derek Arita
I'm in search of some simple rocking chair plans. Let me stress simple, as I am new to chairs. I also have no experience bending wood. I like mission style or arts and crafts, although I like the softer look of mission style. Please let me know if you have a favorite. I recently built one of my daughters a garden bench, so now I have to build something for the other daughter.
Here's a shot of my level of experience...
Re: Looking For Rocking Chair Plans...
What sort of chair would you like to make? There are many plans out there and many types of chairs. Do you have a particular style in mind?
Your bench is a challenging project - so obviously you have tools. What tools do you have? Lathe? Band saw (larger one)? Router? Router table?
The reason I'm asking is that helps determine the type of chair. No use having a chair plan with turnings if you don't have a lathe. Band saw helps in cutting out rockers. Larger band saw makes it so much easier (I'm talking around a 14" band saw) - than a jigsaw. Router and router table means you can use a bit with a bearing and work from a template to smooth the rockers.
Jack Guzman from Maine
design your own
If you shortened the width of that bench to seat size and added rockers you would have it. Look at pictures of various rocking chairs to get the shape and means of attachment.Just a thought.---Jack
Re: This one is fairly easy
Mike Johnson
You might try Woodcraft plans item #409535D. Here's a link to the plans
http://www.woodcraft.com/Product/2081391/31670/Two-In-One-Arts-and-Crafts-ChairRocker---Downloadable-Plan.aspx.
I built two of them and they turned out great.
Derek Arita
Mike, funny you should mention that chair. I already purchased the download version. Was it difficult at all to build? I'm a bit intimidated by the curved back with tenons. Also, not thrilled about having to build a bending jig for the rockers. Did you follow the instructions exactly or did you have to change it up? Were all measurements accurate? Thanks for the help.
Mike Johnson
Hello, Derek.
I had never built a chair before, so I just followed the directions exactly and it turned out fine. The tenons on the curved back did take care, but were not difficult. The bending jig for the rockers worked just as the plans predicted. No need to fear this one - you can do it.
Derek Arita
Mike, thanks. I got the plans on your advice and I'm looking them over. Only changes I may make would be to use and positive-negative form for the rockers and possibly Dominos instead of regular tenons. I know it's not traditional, but floating tenons work well and I can do false thru tenons. If you see a problem with either of these, please let me know. Thanks again!
Derek Arita
Mike,
I'm having a bit of trouble figuring out how I'm going to fab up the side rails with the angled rabbets. Do you remember how you did it? Please email me directly if you can. Thanks.
derekarita@gmail.com
