cutting wood dowel in half
Jack Putnam
I am working on a project that I need to cut a 3/4'' Dowel in half. The Dowell that is cut is about 3" long. What is the best way to do this? Would I have to make some kind of a jig to do this if so how do I build it? Thanks for any suggestions.
Re: cutting wood dowel in half
Jesse Cloud
Make a 'bench hook'. Take a piece of scrap (ply is fine), cut off two pieces the full width of the board and about an inch wider than the scrap is thick. Nail or screw or glue a cutoff on one end so that it sticks up proud of the big piece. Attach the other cutoff opposite the first one so that it sticks an inch below the big piece.
Place the assembly on a bench or table with the piece sticking down hanging off the bench. That will keep the assembly steady while you are sawing.
Mark a line 90 degrees to the assembly on the back piece, use a and saw to make a nice square cut on that line. Make a mark 1 1/2 inches on one side, align you dowel to the mark and cut away.
Merle
Make a V shaped jig a little longer than the dowel. Set your TS to 45* and rip a 2x4 almost all the way through, maybe leaving 1/4" of stock. Then reverse the 2x4 and rip it again to get the V. Screw a stop block to the end on the 2x4 closer to you. Put the dowel in the jig and start cutting it with your bandsaw (Hope you have one). Once the cut is started screw a block on the cut end of the jig to hold it together, then continue cutting until complete. Don't cut all the way through the stop block so you will be able to use the jig again. Clear as mud? HTH
What tools do you have? How accurate do you need this? Is the dowel full length or at least longer than the three inches?
I would use a band saw and if the dowel were longer, set the fence at 3/8" and rip at least three inches. (You are ripping the dowel, right?)
Or you could make a cradle for the dowel to rest in, lay the dowel in it and rip the cradle and the dowel both at the same time. I would cut a flat bottom dado in a scrap for a cradle. If you used a vee groove, the dowel might descend into the vee and pinch the blade.
You could also do this on a TS, but there would be more 'Issues" with kick back and width of kerf.
John McGaw
Dowel is cheap. If you really want two fully-half pieces you need to remove half from two separate pieces. If you try to cut a single piece in half the kerf of the blade, no matter how thin, will guarantee that you don't really have two full halves even though the two pieces might be equal.
I'd do it by marking a longer piece, maybe 9" to provide a handle, accurately and then using a plane to remove most of the waste and then sand down to the line. Then cut the needed lengths.
Orrr...
Tom Dunlap
...if, like John mentioned, you don't really need exactly half the dowel, there's another jig possibility
Bore a hole in the end of a 2x4 or suitable piece. Slip the dowel in and rip the whole works in half. If the piece might rotate a dab of hot glue on the end before inserting the dowel should be enough to hold it in place. A set screw could be bored in from the side if you want something with more Gee Whiz factor!
All great solutions here!
Tom
Re: Orrr...Orrrr.....
If you have a lathe you could glue two pieces together with a paper joint, turn the dowel and then split the two halves apart.
Maybe LV will stock 1/2 dowels for you
You can build it.
Glue 2 pieces of wood together with newspaper in between. turn the dowel on a lathe and then just put a knife in the glue joint and seperate it. You can get the glue and paper off with white vinegar. I did 12 of those with a little more detail in the dowel than what you are looking to do. I did them to replace some pieces missing from an antique clock. Mine were 2" long and little over 3/8" at the widest part.
Do it this way:
Grant in Iowa
First, realize that cutting a dowel in half will result in less than half a dowel on at least one of the parts due to blade thickness.
I would recommend that you use a 3/4" piece of stock lumber and using a 3/8" round over bit in a router table shape both sides of an edge. Use a fence so you can actually get it rounded perfectly. Then rip that edge off of the stock at the table saw. Make sure your offcut is away from the TS fence!
Wash, rinse, repeat to get the quantity you need.
FWIW,
Grant in Iowa
now there is an out of the box solution
One of those "why didn't I think of that" moments
OK Jack, Who won?
You got lots of good ideas. Did you use any of them? Have you done it, How?
