bandsaw blades
bandsaw blades
bandsaw blades
fred dodson
Has anyone used the Viking bandsaw blade sold by Lee Valley for the General 15" on an older General 490 bandsaw? Lee Valley lists the blade length as 98 1/2 but General sets the blade length for the 490 at 100"
Re: bandsaw blades
Re: bandsaw blades
John Veerkamp
measure your current one that way you will get the correct length.. or if you don't have one, run a tape or string around thwe blade path and measure that.
Re: bandsaw blades
Re: bandsaw blades
del schisler
i did a google search and 100" is what you need I don't own this saw this is just off of google search
Aug 4, 2012 - 6 posts - ‎6 authors
I have a 15" General bandsaw that uses a 100" blade. ... a 99" or a 99.75" blade will the tension scale reading be off or does the tension spring compensate for the variation in blade lengths. ... I just put a 99" blade on my 490.
Re: bandsaw blades
Re: bandsaw blades
John in NM
Does your 490 still have the plate where it reads the tension. Plate is behind the top wheel right below the tension knob. My 590 has the max and min blade lengths on that plate. There is a small range of sizes that will work fine, usually +/- an inch or so around a median size. If the median is 100", I'm going to guess 98 1/2 will be too small.
A number of online vendors will make up custom sizes for you, as well as the local sharpening shops.
Come to think of it, the plate in my saw is the same as the 490. If yours is gone I can get you the size range (I'm out of town but I can ask my wife to go look inside the saw :D )
