Craftsman RAS reassembly
Jpleech
Long story here, but I'm trying to reassemble my 1970s craftsmn ras. The shaft that raises and lowers the saw became rusted in the support column that houses it. After a lot of not so gentle persuasion it was freed and lubed. Problem is that I can now not seem to slide the radial arm down onto the shaft from,the top. If I feed it from the bottom it slides in fine until you get towards the top, but once there there's not enough wiggle room to fasten the latching mechanism. Anyone here have Any experience or thoughts on this?
Thanks,
John
