REAL MILK PAINT
Power Feeder Questions
Hi,
Someone local is selling a Grizzly G4176 power feeder. I have been thinking about putting a feeder on my 12" jointer. I work with a lot of large lumber and it would seem like a feeder would make that chore easier.
Anyway, this one is a 1/4 hp model with 4 speeds. Is that adequate power to move long boards over a 12" planer?
Any advice would be appreciated!!
Tom
Re: Power Feeder Questions
Yes, but maybe,,,,,,
Keith Newton
I have put one of my Delta feeders on my jointer to help on those hefty timbers, and it can help, but it does have a couple of drawbacks. Mine is fence mounted, and applies all of the pressure is just a couple of inches from the fence, but if you have the kind with the post and arm, where you can get centered over the blade and effort, that would be better. But even then, on a twisted board, it will press the end down on the front edge, forcing all the twist to be taken off the other. I usually start those in the middle, taking half off each end, leaving more thickness.
Another option that I often use on those mega-boards that are even too big for a 12", is to go at them with my Makita 1806 power-plane. I use winding sticks, and go at it the same as if I were using an unpowered jointer plane. It goes a lot faster being able to take over 6" width up to 2mm depth. There gets to be a time, when it just makes more sense to take the tool to the wood, than struggling to run a big heavy piece on the tool.
Most of the time though, I just skim the beams so I can more clearly see the wood, then lay out my patterns on it. Cut out those planks a little oversize, then flatten them on down before finishing the final shapes. This allows the parts to relieve the stress, before flattening, but you already know that.
But if you don't have a big hand-held power plane, that should be at the top of your wish-list. My young helper hadn't been with me but a few months before he ordered his.
Dick Coers
Is there enough room to mount it and still use max width of the machine? I think the jointer needs more subtle pressure than a power feeder would allow. I'm not sure that it would work well if you have to make multiple passes, and it may also feed too fast on a 12" wide cut. Love them on the table saw, but never even used it a lot because of all the custom work I do.
Thanks
I decided to pass. Mounting it would be a real challenge. And I would be adjusting it constantly or having to get it out of the way for edge work etc.
Thanks Dick and Keith for the good input.
T.
I failed to mention my DIY  pressure roller.
Keith Newton
I jury-rigged a weighted roller that connects to the fence, and is centered over the cutter that I use fairly often. I'm getting material in at the moment, but will post a pic later.
