Drawer runner options
Joe in a Cleveland suburb
Hello.
I've been watching Bill's progress on the desk he is making. In particular I wanted to see how he did the drawer runners because I am making something similar for my daughter - not as nice as Bill's though...
Pictured is my desk in process. It is not glued up. It's just stuck together with boards layed on top that will become the top.
I'm thinking about routing dovetailed slots next to the drawer opening so I can put dividers on the inside running across the front and back aprons. Then I could screw drawers runners to them (that can later be removed and replaced if needed). I'm also going to dovetail in a kicker in the middle of the drawer opening.
Does this seem like a decent approach?
Not 100% sure what I will do for a finish either. My daughter likes it 'darker'. So I read with interest this post by Bill:
http://www.woodcentral.com/woodworking/forum/handtools.pl/page/3/md/read/id/467370/sbj/how-best-to-finish-walnut/
I wasn't able to find Japan color at WoodCraft and they weren't even sure what it was, so I ended up buying General Finish oil based Walnut stain - I like the look Bill gets in the thread above, although my daughter approved what I bought on a sample board. Not sure what I'll put over it though. Probably just oil based poly of some sort.
Thanks.
Re: Drawer runner options
reasonable approach on all counts
The drawer support will work fine. Either dovetail or mortise and tenon which ever you find easier to do. The kicker can be simply nailed to the top or make what ever we call the part the guides the drawer on the side tall enough to screw both the runner and kicker to it.
General finishes oil based stain is a mineral pigment and it will be equivalent to what I described. Japan colors are available from Woodworkers Supply.
I like the table . Nice clean lines. Leg taper just right.
Don't make a clunky drawer. The sides should be no more than 1/2" and 3/8 might be better with a 1/4" or less bottom.
Another thought ..... you could center support the drawer but I am not fond of this technique. No valid reason, just prejudice.
Re: reasonable approach on all counts
Mark
Looks great, I think the drawer plan is sound.
I have made several hall tables very similar to your desk, bit narrower with tapered legs etc.
All of them had drawers with runners basically like you describe.
After the first one, I also started adding adhesive backed nylon tape to the top and side of all my drawer runners to promote a smooth opening and closing of the drawer.
It really helps eliminate binding, as well as reducing any friction that overtime might add wear and tear on the runners and drawer bottoms.
Nice piece !
Thanks guys.
