ADVERTISE HERE - FREE TRIAL
Seam filler for Plastic Laminate Questions
I am working on some Plastic laminate (Formica Brand) counter tops for a rental. Stumbled onto the Bull nose edge treatment they make. So I made the countertops out of "stone" laminate and used the bull nose treatment. I have a seam that is too open for my taste. Apparently my straight edge was not as straight as I thought. (D@mn bifocals!) The gap is maybe .005" at the center of the seam. Somebody makes seam filler (Formica or Wilsonart?, maybe both) Anybody used it? Or I could just fill the seam with CA glue. Any suggestions?
(Other than do better next time.)
Re: Seam filler for Plastic Laminate Questions
Yes
Seam filler comes in small tubes in colors to match. Bit of lacquer thinner cleans up the smears.
Laminate supply house should sell it or contact F-mica or Wilson
yes they make it, but....
Dick Coers
I haven't used it for 20 years. but back then it was something to get the countertop shop off site and out of warranty. Short term fix, basically a thick tinted lacquer. After just a couple years, the crack starts to show as a dark line from cleanups and standard kitchen spills. I guess I could run a razor blade down the line occasionally and refill. If this is one of your flip houses, it will last long enough for that. If you want to try CA, do that on a scrap first!
David Yoho
Barry, you can find the exact filler you need at Wurth behind the Diamond.
Thanks, trying to avoid driving across town. Think I am going to try Central Wholesale on south side off Cofer Rd. Wurth will be my next stop if they don't have it.
Take
a piece of scrap laminate to match the color.
Excellent thought
This laminate is mimicking stone. Lots of variation, reds, browns, blacks and everything in between, I think I will by something in the darker end of the range, maybe two colors.
