REAL MILK PAINT
odd drill motor
odd drill motor
odd drill motor
Jerry Gibbs
Found this unit designed to drill perpendicular holes. The chuck is 1/4" and the motor is one speed, 2 amp. It looks like it cannot be used for any other purpose. Paid $4 at Habitat Re-Store, so no loss if I don't use it. Wonder how many B&D sold.
Re: odd drill motor
Jim DeLaney, Austintown, Ohio
Re: odd drill motor
The drill and guide were sold separately. You had to remove the chuck from the drill, and then screw the guide's shaft onto the drill, then, finally, reinstall the chuck at the end of the guide's shaft.
At the time - maybe 1955~60 - it was pretty 'gee-whiz.'
Re: odd drill motor
Re: odd drill motor
Ralph Lipeles
For some reason many plastics develop a white coating. A rub with water, kerosene or oil should bring out the original color and make it look a lot better.
Re: odd drill motor
Re: odd drill motor
Gary Smyth
If I remember correctly the attachment was marketed as the answer for installing hanger hooks from which macrame plant holders were hung. The legs kept the bit perpendicular to the ceiling and the "bowl" caught (most of) the dust from the drill. After all the effort it took to install the device, I remember some mag with a woodworking hint suggested a paper pie plate with a hole drilled to let the bit pass. The plate blocked the view and the benifit of drilling perpendicular was lost but it did catch the plaster dust.
Re: odd drill motor
a bit more than macrame
Jerry Gibbs
The legs are cut out in a V, a circle and stepped. I assume the steps are for drilling on edge, but the largest is 1 3/4" which is the old 2x thickness.
Re: odd drill motor
Re: odd drill motor  *LINK*
Drill Guide
Re: odd drill motor
You're right
Gary Smyth
For fun I checked the net. I did not find directions but I did find an ad off of Google archives from the Lawrence Journal - World, dated November 21, 1979. I could not get the picture ad to reproduce but the copy states "No 71-055
The newest power drill helper gives drill press accuracy without it sacrificing portability. With it you can drill in at any angle. True 90 degree holes, edge drilling, drills 45 degree corner angles, controls drilling into pipes and round stock, catches debris when drilling overhead. Can be used (without frame) as a 10 inch drill extension. Fits Black and Decker and most other 1/4" and 3/8" electric drills."
"Regular $13.88 (now) $7.77"
Beside it was a ad for a "Black and Decker 3/8" Variable Speed, Reversing Drill No 7127 Reg. $21.88 (now) $17.77"
On the web currently I noticed two -- Goodwill for $5, Ebay for $25
Re: odd drill motor
Tom, We got info from the same
Gary Smyth
source, Google archives, but I could not reproduce the ad I found. How did you do it? Are you using Mac? Explorer? Every avenue I selected reeproduced the total page but I did not find a way to isolate the drill guide ad by itself.
Re: odd drill motor
Re: odd drill motor
Tom Dunlap
Gary,
I use a Mac but I don't think that matters. After finding the page all I did was copy/paste the URL into a reply message.
If I wanted to get a copy of just the ad I could use 'Grab' which is an application in Mac OS that makes it really easy to do screen grabs.
Tom
