After reading Barry Irby's thread about getting robbed I've started to think a bit more about the vulnerability of my shop. A few years ago my shop at work got cleaned out. That was painful and expensive.
I had several thoughts along those lines. (I did not see the one you posted. Either I did not know how to find it or the One Day Deal was over.)
In my case, I wondered if they would simply steal the camera also? I thought about putting a camera or two inside the house. Then I thought about putting a camera or two outside where they could film the doors and the driveway and maybe catch them coming and going with the stuff and get the license plate. Might be able to put those high enough on a tree to make it tough for them to steal them. I was thinking of one o those critter cams hunters use for spying on wild life. Do they use a flash? (not good) Do they work in the dark? (necessary) How long do the batteries last?
Also thought about a sturdy Job box bolted to the floor and putting the tools in it every night. A perhaps two, maybe three hundred pounds of TNT in it as a surprise.
From what I understand, and I could be wrong, the cam does it's work but doesn't record. It sends the video and audio to the cloud where you store it. Even if thieves steal the cam you have 'the tape' saved to the cloud. This cam as infrared LEDs so my guess is that it would work in the dark.
Not in my shop, but down at our cabin. It is a Phillips In.Sight that my nephew bought. One is watching the front door inside, another out, and another toward the creek. They should alert him whenever someone enters the picture. It doesn't see in the dark, but neither do people. We do have a motion sensor light outside.
If someone should break in, no alarm goes off, but we can call the local sheriff, and call the camp phone, which should let them know that they are being seen, and need to get out before the shooting starts. We have a couple of close neighbors that would like to catch someone down there stealing.
The cameras must be in range of wi-fi to work.
Besides these, we have some other tech devices down there. We can turn on the Acs using wemo with our smart phones, so it is cool when we get there. I have suggested that we get another for a bright light inside, just in case someone broke in at night, we could also turn it on, as a deterrent.
I have a monitored alarm system in my shop, which has served me well for the last 30 years. I've been broken into 3 times, and each time, the crooks left when the alarm went off, and of course I get a call before the police get a call. Now that you have brought it up, I think I will add one here too.
And back through the years, I've had good dogs, which can be a good deterrent. But now,,,,,,,,, Sassy would probably lick the boots of anybody that broke in, before helping them haul my stuff away. ha
Here are links to the two things I mentioned above.
There are two versions of night-recording cameras; the flash on infrared versions do not produce a light visible to the human eye. The IR flash versions produce a black and white picture if the flash is activated and a color picture if not. Many display a red LED when activated that can be seen from quite a distance. You can put tape over the light easily enough. The battery life varies greatly among the different brands and versions; usually, it's measured in months.
Make sure the resolution is good enough for police evidentiary purposes over the needed area. Many cameras don't offer enough resolution, or only over too small an area.
