Swollen Chair Leg Tenons
Paul Leuba
I carved the seat and turned the legs and stretchers for 3 Windsor sack back chairs in February and March, and then had to sit the project aside after cutting the leg tenons and drilling the leg holes in the seats. It is now the end of July and I've returned to the shop after dealing with a family health issue to discover that the tenons have swollen with the summer heat and humidity here in central Maryland. They no longer fit the holes I drilled and I believe it is unwise to reduce them in size because they will certainly shrink when the Winter low humidity arrives, and leave me with loose chair legs.
I have considered building a small light bulb powered kiln to reduce the moisture in the tenons and hopefully shrink them back to where they comfortably fit into the previously drilled and fitted seat holes. However, I am not sure that this will work as intended, and I have no information on the size, wattage or configuration of a workshop constructed kiln that would be appropriate for this purpose.
I would appreciate any feedback the forum could give me on the matter.
