Advantages in getting 3 ph table saw?
I am "unhappy" with the current table saw at the Playhouse. It is an old Delta contractors saw. It has stamped steel wings, the arbor is pretty much stuck in the raised position and it won't tilt. It is a single phase 120 V saw.
There is an auction with a 3 hp 3 ph General table saw. We do have 3 phase power at the Playhouse. I could tap off the box that also feeds the dimmer rack and have a long cord over to the work area. Net cost $100 or so for the box and the cord.
Are there significant advantages in getting a 3 ph saw as opposed to a single phase saw?
For home use in a shop without 3 ph, I wouldn't consider a 3 ph saw. The Playhouse on the other hand has a 3 ph box adjacent to the work area so it can be considered - but only if there are enough advantages.
