OT - Kinda. Where the Wall Meets the Trim..
Jim Rahbe
I am working to clean up a house for my daughter and have a couple of questions about the existing door frames.
This house has stained door frames and there is no caulk between the door trim and the sheetrock walls. I’m used to seeing a bead of caulk between the wall and door trim, but then again, I’m used to painted door frames. Should there be caulk between the trim and the walls? If so, how do you keep from having the wall color, then the caulk color, and then the stain color?
Also.. overall, the finish on the trim is in pretty good condition, but there are a number of places that have suffered some bumps and bruises. Anyone have any suggestions on how to touch up the dings without having to refinish the whole thing?
Thanks,
Jim R.
Re: OT - Kinda. Where the Wall Meets the Trim..
Jason Roehl in Lafayette, IN
No caulk on stained trim, that looks hideous with no good way to hide it--better to take care of the gap with good carpentry skills. For painted trim, it is necessary for aesthetic reasons (and nail holes should be filled and sanded flush).
As for wear and tear, clean it, then I'd probably just touch it up with a stain marker that matches the color as close as possible (or a small can of stain and a rag if there's a lot of it). I wouldn't worry much about minor dings and dents--they tend not to show too much on stained trim. If there are major splits and cracks, then that piece of trim may need to be replaced.
Jason
john Veerkamp
Old English Scratch Remover. It comes in two flavors, one for light wood and one for dark wood. It is the "secret" of cabinet and flooring installers. It is available in grocery stores, Wally World, Target etc. Works well, but test first on a out of the way place. Pretty inexpensive stuff.
Justin Szeliga
Nice orange shellac works to get the color to match on old pine if you have to sand kinda deep in the repair process.
As far as the caulk & trim question, you can use a clear caulk, Phenoseal makes a great one, but you still have the dark spot where there are any gaps in the trim/wall line. But you may be able to finesse the paint closer to the trim & cover the gaps a bit.
Clear caulk
In my experience, clear caulk needs to be detailed carefully, for two reasons: if the caulk bead gets wide or slops onto the wood, it can be shiny and ugly; and it can sometimes accentuate the shadow line of the gap and make things worse. If you're going to do this, try it on your least noticeable location first.
Brad Bransky
Agree completely. Wood trim!
Re: Thanks for the feedback..
I thought sure, but OMG!
Jim Rahbe
John,
Thanks for the tip on using Old English Scratch Cover. My expectations were pretty low, but I can't believe what a difference it made. Took care of 90% of my issues. A little hard to find locally. I live in the DFW area and there are about a million Wal-Marts in the area, but only one within 50 miles had it in stock. Lucky for me that store was between my house and where I work.
Thanks again for the great tip.
Jim R.
