About a year ago a storm came though and dumped a big white oak on one of my rental houses. (About $22,000 in damage including $5K to get the tree off the house.) I had the guy removing the tree cut the log into three pieces and set them out up near the street. Once the house was repaired I had the log hauled to a local guy and had it quarter sawed. The resulting lumber is stacked in my driveway under a tarp. I pulled out a board off the top of the pile and ripped it into strips and dressed it. Found a few bug or worm holes.
I suppose I could find a kiln but it looks like a lot of work to move it. I will have to measure it, but the pile is about four feet wide, seven and a half feet long, and nine feet tall.
So, the questions. Were the bugs in the tree? Have the infested the pile since I stacked it? Will they continue to move through the wood? Should I remove the tarp? (I only covers the top third of the pile.) Should I spray with a fungicide? (I have some BoraCare)
Are there spacers between the stacked boards? They might allow you to look at boards within the stack for sawdust, which I think is called frass, produced by active infestation. Whether or not the bugs are present, might be appropriate first to dress a representative sample of the stack to see if the worm holes too extensive to justify further expense.
First, I'm wondering about the tarp. If it came down the sides and prevented cross ventilation, you probably made some bugs very happy by improving their habitat.
However, being in the White Oak family, most likely, they are only in the sapwood. Forget about poisoning them, you are more likely to poison yourself than any of the insects. Nothing you can get will penetrate deep enough to reach them down inside. When the holes appear, is when the adults are leaving to go find a mate, not making their way in.
The best way to kill them in the wood, is with heat. You need to get the stack up to 130º F for 24 hours to kill them, and their eggs. You can do this yourself cheaply, but don't I think I would try it all at once with a stack that high.
You can frame yourself a little floor, to get about a foot up off the ground to make your new half or third of that stack on. notch the legs, so there in ingrain support, rather than all shear on the nails. place your stickers over the floor joist. I use a sheet of 1" styrofoam for the roof insulation, held about 4' above the lumber, then drape a tarp over whole stack.
Get yourself an electric space heater. I have one that oscillates, which is about 6" x 6" x 9", that I have used to set the pitch in pine, and to finish drying some AD oak. I cut a little door, which just fits the heater, and tape it into the opening. Since the intake air is coming from outside the tent, it won't satisfy the internal thermometer which is set on high, so it just sits there blowing hot air in.
On the opposite end, some air needs to escape, and that should be lower than the heater. This will be drying your lumber on down some, because that warm air escaping will be taking a lot of moisture out with it. If you have a moisture meter, you ought to check it before, or as you move your stack.
You can get a thermometer from any good hardware or cooking store to just stab through the top to monitor the temp inside the chamber, or if you have one of those that sticks into the middle of a big hunk of meat with a cable out of the oven, you could drill a hole into the middle of a board, and measure it there.
It may not take but a couple of days to get there, if your weather is hot to start with, and you may not want to just open the stack too quickly after it finishes to prevent too much fast drying at the end as the heat dissipates. It can cool down inside the closed tent, without loosing as much moisture. I'm not an expert on kiln drying, but I would be checking samples along the way.
Heater, tarp, scrap framing lumber, less than $100. My advice $500, total, $600 seems cheap to save that much lumber, don't you think? ha
