pricing a sculpture pedestal
eliot feldman
What's a far price to charge to make a pedestal about a foot square in horizontal cross section and four feet high out of MDF? Nothing fancy. Just butt joints and glue.
eliot feldman
Re: pricing a sculpture pedestal
Robin Corell in Atascadero,CA
I charge for materials +25% and then $50/ per hour for a shop rate. Just an off the cuff guess but probably about $125 sanded and ready for paint and paint would double that.
I have a friend that used to have an exhibit company and he charged $600/pedestal with only slight variations in price for materials. His pedestals were made from birch ply on two sides and 1/4 hardboard for the other three sides and then covered with Formica on two sides and color core Formica on the other three sides. They were beautiful and you never had to re-paint..
Robin
eliot feldman
Just curious about your friend's method: I think of the pedestal as having four vertical sides( no bottom) and a top. So I don't follow about which two sides you wrote about.
fair or profitable?
Dick Coers
Are you a business or a hobby? Have you calculated your overhead? After about 25 questions, including your location, and price you pay for MDF, we could give you an answer.
I traded one for a dog once
There is a lady from Alabama, she is at most Southern Highlands Craft shows, that makes wonderful stuffed animals. A popular model is a huge flop eared dog. I wanted to buy one for daughter who was about 3 at the time but I didn't have the money. (It became her favorite toy and eventually even attended college)
Next to her was a metal sculpture person who had wonderful metal work and crummy woodwork under it. I don't recall how the conversation started but it ended with the arrangement that I got an advance on a walnut sculpture base that covered the price of the stuffed dog and wound up with a steady client for bases.
The artist would design the base shape and I would make it, usually in walnut. The most elaborate was for a business lobby. The center piece was a pond scene with metal fish, frogs , turtles, dragon flies, lilly pads. It was amazing. I delivered it to a business along I-81, maybe Chilhowie, VA. I need to look it up some day.
The bottom line is to charge what ever the client is willing to pay. If you don't want to work for that amount then don't do it.
Keith Newton
Are you saying, no bottom or top? I'd be sure before you agree to a price.
I'd be close to Robin in my estimate, only for mine, I would use 1/2" mdf all the way around.
I made a bunch for myself, which were all 6 closed sided cubes of various sizes. Then a few years ago, had a joint show with a friend who teaches at UALR. His were all open on the bottom, and sized a couple of inches smaller, so they could store inside the next, by about 6 deep. More weight than one person could lift, but easy to tip over, and slip a hand-cart blade under for easy transport. Wish I had done mine this way.
Don Stephan
Butt joints will telegraph through paint, probably through wood veneer as well. I miter the joints between the sides, and between the sides and the top, and include a spline in the joints between the sides. No bottom. Plastic resin glue has the needed open time, paint on all joint surfaces, then assemble as second glue coat painted on. Allow time for dry run and to clean up squeeze out after glue cures. Collins spring clips to assemble.
The first will take twice as long, take lots of pictures and notes so the following ones are faster.
Two vertical sides would be done with 1/2" birch ply and the other two sides are 1/4" hardboard (masonite) cut oversize and trimmed with a flush trim router bit. The reason for the two different materials is to eliminate having any plywood end grain which can be problematic to laminate with Formica.
Cutting the sides oversize and trimming with a flush trim bit is something I do as well but I use 1/2" mdf for all the sides. It's much faster than trying to line the edges up perfect and having to full when you don't get things just perfect. I space a few glue blocks 5/8" from the edge which act as stop blocks for the 1/2" mdf and to leave 1/8" overhang to be trimmed with the router.
Robin
