HVLP vacuum template *LINK*
Keith Newton
This is sort of off topic, in that I was using this to crank out a bunch of plastic parts, this can be used for wooden parts as well.
I have a couple of friends whom are building a business selling 3form Inc. plastics , which is getting fairly popular among the architects. They don't have a shop, so I usually work them in.
It is easier to get a good finished edge with a router, than with a saw, so when there are a lot of like parts, we will make a router template. If there are only a few, I'll just use carpet tape to hold the two together, but then, there is a need for someone to hold it down to the bench, unless I use clamps, which takes longer.
We had 56 parts to run today, so to make holding the parts to the template, I got over on the end of one of my work-tables, and cut a hole up from the bottom, which would accept the end of a shop-vac hose. Then I cut the middle out of each of the templates that we needed, and sprayed the face lightly with a light coating of spray contact. After this dried, it acted as a rubber skid resistant surface for the vacuum to pull the plastic down against.
A few years ago, I was wondering how to measure the negative pressure produced by the average shop-vac. I had tried many years before using the Hg on my vacuum press, but couldn't tell that it even moved, so came up with the idea, to just cut two 12" x 12" squares of mdf, then put my bath scales in between, with a little window cut out in the top one, so I could read the dial. I slid that into a clear plastic drum liner, then flipped the switch, while I just held the bag tight around the hose. I was surprised to read 150 # per square foot.
Since there are 144 square inches per square foot, I thought that was close enough to just round it off to expecting one psi of pressure on the bag. Or in this case, I had cut a 5" x 16" opening into the template, which would provide 80 pounds of pressure pulling the part against the template. It was quick to make, and apply and drop. My cycle time was about 80 seconds per part, which included peeling the paper off the back of each part, which wasn't stuck well enough to leave on, routing, blowing away the chips, dropping the van, and moving the parts into a new stack.
This high volume at a low pressure should be handy for some applications with wood, where the leaking, or bleed through of a higher pressure pump, pulling through a smaller hose might not be able to keep up with. Atmospheric pressure being so low, will only push just so much air through a 1/4" or 1/2" hose, whatever most of you would normally be using with your vacuum pumps.
Here are a couple of shots of this simple setup.
http://www.flickr.com/photos/7391658@N03/sets/72157634671296062/
