Removing glue Question
I got some glue on my favorite pair of none shop pants. Titebond. A line about two inches long and a 1/4" wide. Any good idea how to remove it?
Re: Removing glue Question
waroland
Suggestions from a Pro Dry-Cleaner:
a. take an old rag that is clean, lay it over the stain, and hit it with an iron on it’s hottest setting. If the glue can be heated up to the point of re-liquifying, you may be able to wipe most of it off.
b. There is a product in our industry we use for plasticized adhesives called amyl acetate. If you can soak the stain with this stuff for hours, then maybe it will start to break it down. If it works, then just flush it out with naptha or mineral spirits in a rag.
wash pants
I wipe glue on clothes regularly.
Hot water takes these adhesives off about anything. I clean out my glue bottles from time to time with hot water as well as remove glue from spreading spatulas, etc.
Depends on which Titebond
Dick Coers
I use III to glue seams on clothes all the time. Won't come out in the laundry. What about vinegar? Won't that soften original Titebond?
Vinegar works
Warm vinegar works faster.
Something to be aware of - some dyes are set with acid - so test an unobtrusive area of the pants first. Usually the dyes are pretty set, so there is nothing to worry about, but sometimes..... Another thing - it will corrode metal somewhat - so take caution.
Howard Acheson
What version of Titebond did you use?
According to Titebond, the Titebond III will not be dissolved or softened by water(cold or hot) or vinegar. They say there is NO solvent.
Tony - Memphis
I kept a sample of two pieces of wood glued together with Titebond III in the dishwasher for a couple of weeks and it never gave up! Wow!
Tony
