Attaching coffee table top with....?
Brad Bransky
Do you prefer buttons, cleats, screws through the underside of the rails, or what?
Brad
Re: Attaching coffee table top with....?
Solid wood top needs "S" clips or figure 8's
Depending on the design, I've fixed slab tops with 2-3 screws into the centerline of the table top.
John in NM
I usually make a large pocket hole with a carving gouge and put the screw through an oversized hole. Shop I used to work for used figure 8's or those steel clips, they both work fine too.
Is it a solid wood top?
Dick Coers
Is it quarter sawn? Need more info for accurate help.
Re: Is it a solid wood top?
Brad Bransky
It's quarter sawn white oak. I grooved the rails and made wood L shaped blocks to fit the grooves and screw into the top. Got the idea a little while ago on the Woodcraft web site. It's also mentioned in the Fine Wood Working online site. They call the blocks "buttons".
Thanks for your help.
I love this forum.
Brad
Quartersawn Helps
David Yoho
The wood movement across the grain will be minimal, which will help. However, I like using the "button" method as well as the metal "Z" clips.
Don Stephan
If memory serves, "on average" QS moves half as much as flat sawn, which means "on average" 1/16" per foot of width over an average year.
I like buttons, and use quite a few as the common practice is to lift a table by the top and not by the apron rails.
Jim Dillon
Brad,
I've used the figure "8" and "Z" clips, but now only use the wooden "L" buttons placed into mortises cut with my Festool Domino. I make sure to orient the grain of the buttons so they are less likely to break. While the metal clips are sure convenient, I like the look of the buttons a lot. I countersink brass screws in the buttons, but cut the threads in the hard wood with steel screws to avoid breaking the brass screws. Coincendently, I'm also building a QSWO coffee table right now and am using the wooden buttons.
Jim
Brad Bransky
The above responses are yet another testimony regarding the value of this site.
Excellent information from which to learn and apply.
Jim, the consideration of grain direction of the buttons is excellent. I never thought about it and you are correct. If not perpendicular to the groove, they could break, especially on a 1/4 white oak coffee table which is crazy heavy, thanks.
Brad
