How was this made?
How was this made?
How was this made?
Denny
Here's a photo of an Esherick victrola cabinet that has me wondering about how it was made. It looks like frame and panel construction, but the panels don't seem to have any room to expand, more like a jigsaw puzzle. I'm guessing the longest cross grain dimension is about 5 inches, but it looks like it hasn't caused any problems. If you look closely you can see that the frames have some pins visible, so I'm assuming he assembled it all with mortise and tenon construction, or maybe tongue and groove or even half-laps. Thoughts?
Re: How was this made?
Keith Newton
I would bet M&T,or bridle joints. Notice that it is rift, or maybe quarter cut, which should cut down on movement. Is that Walnut, or one of the rosewoods?
I've done some pretty small reveals in panels like this before without problems. You just want to make sure that you lumber is close to EMC when you make it.
Brad Bransky
Looks like walnut with M&T for the top and bottom inserts. You can see the tenon pins. My hunch is tongue and groove for the long triangular (forgot my 8th. grade geometry terms) pieces.
Dick Coers
Those pins are way into and past the center of the stiles. Had to be bridle joints. Looks like everything has a big reveal, even around the rail and style joints. If all solid, I would be worried about that really wide rail going into the narrow style. Looks like plenty of room for the panel to move.
Don Stephan
Not familiar with his work, could it perhaps be veneered? All but one of the matches are very good, but it could be resawn lumber. Wouldn't think there's a lot of overall strength in the front face, but it could be using a sub frame to reinforce it.
Auction listing says made from padauk *LINK*
Dick Coers
and several more pictures. In the one view you can see a bit of end grain on top of the style suggesting tongue and groove.
http://www.liveauctioneers.com/item/5739573
Extremely helpful
Denny
I think I have enough info now to get started on a cabinet inspired by this piece. No more padauk for me though, if I track anymore of that red dust through the house I'll be in trouble. I don't think mine will be selling in the $50,000 range either. Thanks guys, really helpful.
Denny
