Off topic: insulating walls
I'd been planning, in the current remodel, to insulate the walls with sheet foam (preferably polyisocyanurate for its higher R-values) sprayed in place with the spray-in-a-can. I am now getting very confused, though about vapor barriers. Polyiso and spray foam are both very low in permeance (at least what I can get around here; can't get unfaced polyiso). That would have made the insulation the vapor barrier. However, because the walls on our old house are unsheathed, we're sheathing with 1/2" CDX on the inside of the framing, for shear strength (that is then covered with drywall). And the reading I'm doing indicates that plywood is relatively low in permeance. If I insulate with foam, am I creating a double vapor barrier that could lead to mold in the wall cavity?
