band saw sharpening
band saw sharpening
band saw sharpening
Brad Bransky
I live in Lawrence, Kansas (go hawks!) and have need for sharpening of several Timber Wolf band saw blades but can't find anyone in the Kansas City area whom will sharpen anything but graphite blades.
Does anyone know of a sharpening source it the KC area. I called Superior but they only do graphite.
I'm a bit apprehensive about "Do it yourself sharpening" on the web.
Thanks,
Brad
Re: band saw sharpening
Not to discourage you, but
I've never found anyone who would sharpen bandsaw blades for less than the price of a brand new blade. Since they charge by the tooth, run-of-the-mill bimetal blades wind up costing less to buy new than resharpen. A new 102" 3tpi T-wolf is about $20. Good luck finding somebody who'll resharpen 300+ saw teeth for $20.
If you look in the Articles sections here, you may find a write-up on sharpening your blade on the saw using abrasive disks. I tried it once with little success, and decided it wasn't worth the effort.
YMMV ;)
Dick Coers
If you can't find someone to sharpen, go ahead and sharpen them yourself. I am very happy with the result. I use a disc on a Dremel and touch just the top of the tooth. It's not like you have to really grind it, just takes a touch to refresh the tooth. I won't say it's as good as factory, but it is very much improved. I'll do that twice before the blade goes in the recycling.
Brad Bransky
Thanks Mark and Dick, very helpful comments. I think I'll get out the Dremel and give it a whirl, so to speak.
Brad
Don in Central Illinois
Instead of a Dremel disc, I use a 3/32" stone. Doesn't take as long as I thought it would and like Dick, you can prolong the blade for awhile.
Brad Bransky
Thanks Don,
I have a variety of files for sharpening Japanese saws. I wonder if they would work or be worn down too fast.
Brad
I use Don's method. I touch up the outer flat and then touch the gullet slightly tilting the dremel left and right to match the shape of the tooth. Takes about 15 minutes and gives me a usable blade. Haven't tried to sharpen blades that I use for resawing. That's a much more critical task. However touching up the blade only takes a short time and you can always test it on scraps to see if your sharpening job improves or messes it up. Nothing lost in trying.
