I come off oncall duty this morning and I will have a couple of days off from work as well. I will spend those 2 days working on more renovations to the house that we have been doing for the past 2 months. I will be nice when it's all done, but in my own mind, the light at the end of the tunnel keeps moving further away. Every time I turn around there is something else that needs to be done "before" I can put new flooring down or new door casings in. This has been a real stretch for me mentally and physically. I think the emotional part is sneaking up on me because my frustration level is starting to build because this is taking so long.
Well, that's all for me...so what did YOU do this past weekend?
Having finished a walnut table it was time to clean up the shop. Most of the time I sweep up the sawdust, shavings etc and leave it at that.
This time I decided to REALLY clean. Outside was 111 degrees [44 C for those in the rest of the world], cooler than the 120 degrees last week, and the shop was a bit over 100. I turned on the little wall A/C and the shop slowly cooled down to the low 90s. That was sweaty but tolerable. A concrete floor is a large thermal mass so it would take quite a bit of cooling to really get the shop to a comfortable room temp.
I brushed off all of the fine dust on the walls [didn't do the ceiling], moved and cleaned off or vacuumed all of the tools, bench, racks and every piece of wood. Cleaning the dust from all of the lumber led me to reassess the need for a great many cut-offs and odds and ends that I'd put aside "in case" I ever needed them.
A frequent Q: was 'what on earth did I save this for?'
I now have two large boxes of hardwood scraps that I give to my neighbor to use as kindling. They use their fireplace and also have an outdoor fire pit on the patio. It almost pained me to make more dust by using the saw to cut some of the longer pieces into foot long kindling. In the heat of summer I didn't call them -somehow the offer of a fire didn't strike me as appropriate.
Not exactly an accomplishment... but I was inspired. I was in the Ashevile NC area and seemed to recall a not so recent posting where Ellis commented about about furniture at the Grove Park Inn. I checked on their website and found reference to the Groveland Gallery and decided to check it out.
The 2nd floor is filled with wonderful 'studio' furniture - in a wide variety of styles. Influences of Krenov, Maloof, and Nakashima were certainly evident. I came away wanting to raise the level of my own work a notch, or two, (or ten?!). if you are in the area, it is worth checking out! Note this is not a show - just a gallery with artisan pieces for sale.
I was told there is currently a wonderful show of turned pieces (I forget the artist's name) at the Asheville Art Museum - but alas, they were closed on Mondays, so I could not see that.
Half way down, it dawned on me that I had forgotten my camera. Bummer!
Worked on my cousin's cabin some. It has come a long way from it's Sow's-ear phase, but still a ways to go.
Did some yard improvements. We have lost some pretty large trees around there, and some of the other large ones are Water and Willow Oaks, which are short-lived trees, due to their low resistance to rot. So I dug up a ~5' tall Swamp Chestnut Oak from out near it's parent tree by the drive. Dang that thing had one heck of a deep taproot, which was of course tangled with some Hornbeams.
I had recently sharpened my chainsaw, so was really disgusted when I attempted to cut a 5" diameter Blackgum, and 2" in, hit a big nail. I sharpened it again, only to hit another after cutting only 1/2" into the same tree, at ground level. Sharpened again, then moved on to another tree, only to hit another in it. At that point, I switched to my machete, and half expected to just be hit by a stray bullet or something. Hell, at that point I would have almost welcomed it. ha
My newly planted tree was looking good when we left, so I have high hopes for it. I may move some more of the small seedlings to other locations where the future shade will keep the cabin cooler. Swamp Chestnut Oak is well suited for there, having good decay resistance and flood tolerant, and a great root system.
