Making a secret compartment
SWMBO purchased a sideboard for use in the play "The Murder Room". She would like a secret compartment. Rah. There are two cabinets with doors on either side of two drawers. She would like the cabinet to be sort of obvious so that one of the female leads can bump into it and have the compartment exposed.
If I make a drop down drawer and put in under the apron trim, that might work. But I need a source of suitable hardware that will keep it up. Any thoughts?
Re: Making a secret compartment
Magnets?  Touch latches?
Both available at your friendly local home center.
gary Smyth
In order to have a greater reliability of it doing what you want when you want it to do it without something being obvious to your audience, you might want to consider a weighted door/drawer with a manually operated cable release. Having someone out of sight (or even on the set) operating the release on a cue will not be a problem for a play. A spring cabinet latch with a ring will make the cable (clear 80 lb. fishing monofilament) release simple. Maybe something like shown.
Magnets with a wedge to release it. push in the wedge and it drops down. Not much simpler and very reliable. You can make the wedge with a spring return so that the "button" doesn't show after it's pushed. You can also make this a lever action if that is easier to incorporate into the drawer.
Ralph Lipeles
My grandfather built furniture and restored antiques for the Frick museum. He always had secret compartments in the furniture that he built. He would usually just make a small drawer with 1/4 by 1/4 runners at the top of each side. He would then make 2 side pieces, maybe 1/2 by 1/2 with a 1/4 by 1/4 groove at the top. These side pieces were glued to the underside of a shelf in an area where they would not be visible, usually by the center partition. The secret compartment was not visible but you could reach in, feel it and slide it out.
Ralph Lipeles
