Panning for 'gold'
Panning for 'gold'
Panning for 'gold'
Tom Dunlap
A couple of days ago I started another phase of my camper build. This part is metal work...including about 400 pop rivets. The jaws on my manual gun were slipping so I disassembled/cleaned it at my workbench. In the process of reassembly I, of course, fumblied one of the jaws! I heard it hit my floor mat but not bounce. The floor, of course, needs sweeping and its covered with sawdust and metal shavings.
This is one of the jaws in a paint tray:
My first plan involved using my 90 degree welding magnets. Not enough power to pull the iron out of the sawdust. Then I grabbed one of the rare earth magnets that reside on the top of my tool box. It stuck onto the tip of a screw driver which I could swirl through handsful of floor sweepings at a time. Slow..but I was making progress.
Wait a second...more power...brumphhhhhh...I put a row of magnets on the bottom of the paint tray and sifted the debris across from the shallow end to the deep end. I did find a dime in the debris!
I was getting discouraged because I had swept the floor under the mats and rolled my workbench aside. The next step would have been to start moving cabinets and getting into the nooks and crannies.
There was one last pile, about the size of a soft ball, that I scooped up. When I dropped it into my 'gold pan' I heard a click...a couple of shakes...and there was the other jaw. Yup...last scoop. At least my floor got [partially] swept.
the rare earth magnets came from a buddy who does computer repairs. They're from trashed hard drives. Having them around has solved many unique problems.
To keep a stash key for my vehicles I bolt or pop rivet a washer to the key and stick a magnet inside a part of the frame. Much stronger magnets than in the plastic boxes.
Here's my project:
A former Toyota Uhaul boxtruck. I cut-in the RV door up front, firred out the walls, added 3/4" foam insulation and paneled with 5x9-1/4" plywood, FRB ceiling. I extended the frame 25" and added a 2" receiver hitch. The frame for the extension is some 2" tubing from the salvage yard, buck a pound I think. The sheeting is glued and pop riveted...I'm getting a HF air riveter today! The back will be closed in with barn doors.
After the metal work is done I'll move back indoors to start making cabinets/shelving.
Tom
Re: Panning for 'gold'
An Attractive Method, Tom
But cleaning the shop more often can save time, not to mention "prospective" efforts :D
Re: An Attractive Method, Tom
BeaD
"There was one last pile, about the size of a soft ball, that I scooped up. When I dropped it into my 'gold pan' I heard a click...a couple of shakes...and there was the other jaw. Yup...last scoop. At least my floor got [partially] swept." Yep, it was the LAST pile "cause one stops looking when the item is FOUND" Ha! Ha!
A/K/A
"Stop drillin' when you hit oil." ;)
Tom Dunlap
If the jaw weren't there in the last swept up pile I would have had to 'go deep'...behind cabinets...lucky me, for once :)
Cute puns too!
Tom
Kneale Brownson
For the future....
Kneale Brownson
When I'm working on something like that with small parts, especially little circlips and springs, I do my disassembly/reassembly inside a large, clear plastic bag.
