Squaring up a cabinet using band clamps
Howard in Toronto
I've used conventional clamps on the diagonal to square up carcases before.
But this weekend I'm starting a biiiig one. Seven feet long. Longer than any clamps I own. And the diagonals will be that much longer. So I'll use my band clamps. My biggest concern is, if I need to, how do I square up a cabinet when the primary clamping is from band clamps.
Any ideas?
Thanks.
Howard
Re: Squaring up a cabinet using band clamps
Jason Roehl in Lafayette, IN
Think around the box...
...but in a different way.
Instead of wrapping around the carcass so that the band clamp touches wood all the way around, wrap the band clamp diagonally around the carcass so that it's only touching the the front-to-back corners in the upper left and lower right, or upper-right and lower-left.
In other words, one clamp would go from upper front left corner, to:
lower right front corner, to
lower right rear corner, to
upper left rear corner, to
upper left front corner (the starting point).
Make a couple corner cauls if necessary to hold the band on the corners.
Jason
Re: Think around the box...
Robin Corell in Atascadero,CA
If you have some pipe clamps just pick up a union fitting or two at the hardware store and put two or three of the pipes together to create a clamp long enough to suit your needs.
If your working on an open case our cascade you can use a scrap 2x laid across the diagonals. On one end screw a block and place that one on the outside corner. near the other end of you 2x screw a block but in the open area of the carcass. Then use a bar clamp on the second block and the outside corner to square your cabinet.
Robin
Yonak
If you can clamp Jorgensen clamps to each corner of the long diagonal you could run a string between them and tighten the string to bring the corners closer.
