Rehanging Door
Rehanging Door
Rehanging Door
Stuart Johnson
A couple years ago we had a worst than usual hot, dry drought. Even with regular foundation watering I had some slab movement but not enough to warrant one of the service to make major repairs.
I do have a problem with one door frame:
The frame has lifted enough so the latch is being forced up against the lock. I'm trying to figure out the best way to re-square the frame. After taking this picture I removed the molding from the side and top. There are shims on the side and bottom but not the top. If I cut them free can I then adjust the frame to the door? Would a picture of the shims help with the answer?
Re: Rehanging Door
Size of the rough opening is critical here.
Dick Coers
You will be trying to fit a square block into an irregular hole. Having enough clearance around the square frame will dictate how close you can come to that. I've never worked with a side light that big. Not sure how that center jamb is worked out to take the load from the hinges. Usually all the fasteners (nails in the jamb, and at least one long screw through each hinge) hold the door in place. I also don't know if this is just a plumb issue, or the floor has also dropped. You may have to get creative with the threshold if you want to bring the entire thing true.
Re: Rehanging Door
Re: Rehanging Door
basil
I had several doors in an old home that had settled just enough that they wouldn't latch/lock.
I chiseled out (elongated up or down as needed) the hole in the wooden door frame and filed out the opening in the metal strike plates until they worked just fine. Beat rehanging all those doors.
Re: Rehanging Door
You can also re-set the strike plate
The light showing above the door implies that you've lost your weather seal, though, if this is an exterior door, so you may have more than one issue to resolve.
This can get complicated, particularly on exterior doors, where you have to pay attention to weather protection details. It looks to me like you might need to re-cut the jamb on the latch side to let it drop down; but, if there's a threshold in the way, this can get hard (an old fashioned handsaw, or the Japanese equivalent, is often the best tool for this kind of trimming).
More pictures and description would help.
Re: Rehanging Door
Re: Rehanging Door
The first thing you need to do is figure out what happened. In what manner did the opening shift? It appears the left side or the strike jamb has been lifted in relation to the center post. Or the center post has dropped or settled. The margin up the strike side appears fairly even, so I am assuming the door did not shift out of plumb.
Put a level on the hinges and see if they are plumb left to right. Check them at ninety degrees to that. Then check to see if the top of the door is level. If the hinges are plumb, you mar be able to shim under the center post and raise it until the margin i even across the top of the door. You will also have to shim under the right (fixed) jamb, in effect raising the fixed side light. You may need a taper shim under the sill or a sequence of shims to support it. All of this will require enough apace around the door to move it.
You could just water heavily under the fixed panel and let mother nature jack it up. ;)
The easiest thing would be to move the strike plate.
Re: Rehanging Door
Re: Rehanging Door
Keith Newton
If that little trim across the bottom is base shoe, I would pull that off, then see if you can raise the middle by driving a wedge under the middle. If there are shims over that point, take them out first.
You can shoot some expanding foam under that space.
Besides filing the striker plate, I've been known to file or grind the top or bottom of the striker, if removing the facings is going to cause a bigger mess.
But you do need to fix that air gap over the top of the swing side of the door.
