I want to be able to spray solvent based finishes in an enclosed garage type building. It has windows, people door and a 16' garage door. How do I safely spray solvent based finishes without buying an explosion proof fan. Thanks. Jerry
Open the garage door and put any fan near the door blowing out. There won't be enough concentration of vapors to explode..
Your average fan won't spark anyway. In the low probability that the switch on the fan might spark when turned, just turn on the fan before you start spraying.
I use a 48" box fan when I spray. Just to see what would happen I sprayed pure lacquer thinner into the motor from about three feet away. Nothing happened and yes the fan was running at the time.
...were you above the upper explosive limit of the lacquer thinner, or below the lower explosive limit of the lacquer thinner? If you were below the LEL, then there's little chance of much happening, but if you were above the upper, then as the concentration drops as more fresh air mixes in, then there would be a chance at an explosion.
Pardon the pun, but I think the fears are "overblown".
most motor's are induction, not with brush's, so no spark's, also most switch's are sealed more or less, i have used 36" fan installed in to my shop window for yrs and never had any trouble, have to clean the window now again, the lacquer doesn't build up on the motor, i use my air hose to blow all dust and what ever get's into the motor it is clean and work's for i know 10 or so yrs now, i have another one in the other side of shop, which i don't run when spraying , all of the small over spray goes out one window fan, i use a HVLP unit with 30 lbs of air very little over spray at all, i would say don't worry about what you are doing is going to do anything but move the over spray out the door, it will eveaperate enough, i wouldn't spray nothing with the door's closed not good for breathing good luck my 2 cents
