Finish for Table
Finish for Table
Finish for Table
Kelly M. Robison
I am in the process of re-finishing an old antique dining room table. It is an old solid Oak table with 2 leaves. I have sanded it down to the bare wood and found a stain that will match the original. Now my question: I want to put a finish on it that will look good and still be water proof; any suggestions or recommendations??? I plan on putting several layers of stain on it and using steel wool in between. I want something that is easy to apply but also durable. I don't have a sterile "paint room" but do have a heated clean room that I can apply the finish and I'm not worried about the time it takes to dry. This table will be used on special occasions but not abused, but people might put down glasses with liquid in them on the surface; so I want something durable.
Thank you,
Kelly in Port Orchard, WA
Re: Finish for Table
I like polyurethane for table tops. Thin it about 1 part solvent to 3 parts finish and it will brush and level better.
Clint Searl
Clint Searl
Waterborne poly floor finish. I like Varathane or Bona Mega.
Don Stephan
My suggestion is 2 or 3 coats of oil-varnish blend - equal parts mineral spirits, boiled linseed oil, and good varnish (I use P&L 38 gloss). It can't chip because it doesn't build a film, and is easy to renew in a few years should the need arise, by applying another coat. Application is simple - rag on, wait 10 minutes and wipe dry with clean paper towels. Allow at least 48 hours between coats.
Sounds like a lot of work, but I'd suggest getting some raw wood as similar as possible to your table, and apply the entire intended finish schedule. Even better, make a 2' x 2' sample using each finish contender and then eat a few meals on each to evaluate how the finishes stand up to the expected use.
John Pappas
Kelly, you say you want to apply several coats of stain and steel wool inbetween coats....
Read instructions for stain. Normally stain is not built up like a finish is. I would apply one coat and wipe down well. The old addage is to test what you are planning on doing...easier to throw away some test scraps than to redo the table.
Brad Bransky
Hold everything, Kelly! If the table is of the Arts and Crafts style, it may have originally be fumed with aqueous ammonia, then finished with orange or amber shellac, followed by coating with a paste floor wax, especially Johnson's.
Brad Bransky
Lawrence, Ks.
Re: source for PL 38?
Don Stephan
It's made in Cleveland and here in Cincinnati I'm able to get quarts from a local paint store and local woodworking supply store.
Pete in Holland, MI
4 coats of Minwax oil-based poly on my table and has survived 15 years of boys.
Any finish will scratch. That will always be a problem. There are some on mine.
Block sand lightly between coats to get rid of the pricklies. Steel wool is better on contours. A flat block behind the 150 grit sand paper does better at knocking off the high spots.
Work quickly when applying the varnish. Should do a dining room table top in less than 5 minutes. Don't work backwards, else you risk disturbing finish that's starting to jell.
Pete
