Re: Finishing help!
Gary Smyth
I hope I understand your specific situation. If the chair was pre finished why use a sanding sealer? What was on it before you sanded it down? Paint? Shellac? Varnish? I found two brief articles that may lend you assistance.
Michael Dresdner via Woodworker’s Journal: “Sanding sealer is never mandatory — it is an option that saves time and material in some situations, and is unnecessary in others. Some woods, like cedar, spruce, and poplar, are so porous that they tend to suck up the first few coats of sprayed lacquer as if nothing were applied. Other woods, such as walnut and mahogany, require a good bit of sanding to level the pores even when pore filler is used. In both cases, the material of choice would be something that builds up quickly and is very easy to sand. Enter sanding sealer.
“Sanding sealer is lacquer, or some other basic coating, with zinc stearate added. The stearate, which is a soft, fluffy soap, adds loft to the lacquer, making it build up and fill in pores much faster. It also makes the lacquer softer, and acts as a lubricant when sanding, so that sanding sealer powders off quickly and easily. These characteristics make it ideal for trimming both the number of coats and the amount of time spent sanding them. This is especially helpful when you are trying to build a perfectly flat, pore-free finish. It is useless, in fact, counterproductive, for the open pore “natural” look finishes more popular today.
“A word of warning is in order. The stearates make sanding sealer rather soft. If you put a hard, brittle finish, like lacquer, over a thick, soft one, like sanding sealer, it is much more likely to chip and crack. For that reason, if you use sanding sealer, stick to one or two coats at the most, and plan to sand most of it back off. For the same reason, and because it tends to shrink as it cures, it is not advisable to use sanding sealer instead of pore filler.”
From Minwax: A sanding sealer is not the same as a wood conditioner. Whereas a wood conditioner is a pre-stain treatment that reduces blotchiness when staining, a sanding sealer is applied only to bare wood that is not going to be stained. A sanding sealer can be used on bare, unstained floors, doors, furniture and cabinets prior to applying either an oil-based or a water-based clear finish. It is designed as a base coat that will dry quickly, seal the pores, and sand easily with fine sandpaper to create an ultra-smooth foundation.
My experience is that sanding sealer limits penetration of stain. That may be what you are looking for but you have to decide for the project you're working on.
