THE WOODRAT IS BACK!
Pre Hanging Double Doors
Larry
I' looking for information on how to Pre Hanging Double Doors.
Thanks
Re: Pre Hanging Double Doors
Do you mean?
John in NM
How to install a pre-hung double or how to make a pre-hung double and then install it?
Re: Do you mean?
Larry
Re: Do you mean?
John in NM
I've never made one, I usually make an old style door jamb instead. Doing a one off, you don't save any time making it a pre-hung style, that is for factories cranking out hundreds of them.
Have you built and hung doors before? Making a pre-hung jamb is about the same as a regular one, you just don't want it as stiff. Since the door is already in the jamb when you install it, you have to plumb the door using the shims against the jamb rather than install the jamb plumb and stick a door in it. For this, the jamb parts are usually a bit flexible, though you could probably do it with a heavier jamb too - I've never tried that.
Dick Coers
Only did it once. Mortise the hinges like always. I made the right door (while standing outside) as the primary. I epoxied a wood astragal to the left door, and silicone bulb seal to seal the right door to the astragal. Sliding bolts into the top jamb and threshold for the left door, lock set into the astragal. google images is your friend.
Larry
I know all that. Say you have two 36" doors, how much do you allow between the jambs? 72 1/4" ?
Thanks
Depends on the astragal
Dick Coers
If you make a T shaped astragal, then you subtract the leg. If there are kids involved, a T shape is much stronger when the doors are slammed. We have to know what kind of weatherstripping you are going to use, what species of wood, the width of the stiles, if the wood is flat sawn or quartersawn, etc...... Any rules of thumbs or guesses from us will only make problems for you. Design it out when you know the hardware and weatherstripping, and study wood movement charts.
Re: Depends on the astragal
Larry
Guess I should had said that it's an interior door.
