OT Diesel oil chg
OT Diesel oil chg
   OT  Diesel oil chg
Frank G
Just had my oil changed by the dealer on 2010 Dodge Diesel 7 days and 72 miles ago. or some reason I pulled the dipstick and the oil is black. I know the stuff turns quickly but. Maybe I am the victim of a quick drain and plug it early situation, causing a lot of the old oil to mix with the new. .
Has anyone checked their oil after less than a 100 miles and noticed the color of the oil????
Re: OT Diesel oil chg
Jay St. Peter
Diesels turn oil black quickly. If you want piece of mind, get a kit from the auto parts store and send a bit off for analysis.
basil
Yep, the fresh oil turns black almost instantly.
If you drive it mostly short distances or run it for short periods of time, you may want to change the oil a little sooner than recommended. Otherwise, buy clean fuel and keep it clean, use the proper motor oil and filter, clean air filter regularly and change all as recommended....and don't worry about the color of the oil.
At one time I was running 16 diesel engines not counting my pickup. Yes, it's kind of disheartening to put fresh oil in an engine and in a few minutes it looks as bad as what you just drained out of it but that's the nature of diesel engines. The smallest engine took 5 gallons to change and the largest took 16 gallons to change. They used fuel at a rate of 6 gallons an hour to 12 gallons an hour......at todays prices, I am glad those days are in my past.
