Band saw slippage
Band saw slippage
Band saw slippage
Philip Duffy
Two days back while sawing a modest size of dry walnut I felt, and saw, the blade slow down! After checking all the things that could cause such a problem I opened the bottom section door and discovered that the set screw of the drive pulley had slipped, thereby causing the shaft and wheel to have very little in common. A simple Allen screw tightening fixed the problem straightaway.
Check your Allen screws!
Re: Band saw slippage
Re: Drive wheel slippage
Philip,
You should check that shaft to make sure it doesn't have a machined flat to accept the set screw. If it does, back out the screw, realign so the screw will engage the flat, and then retighten. Also not a bad idea to apply some loc-tite to the screw to help prevent vibration from loosening the screw. Some saws use a key and machined slot to prevent this issue.
Re: Drive wheel slippage Another solution
The previous post was correct, another thing that works well (and is normal in industrial machines) is to tighten the existing screw well, then insert a small copper plug and tighten another set screw down on the first. Reason for the copper plug is to prevent malformation of the existing set screw head so a wrench will fit later! The copper slug can be eliminated if you use a "cup head" set screw as the last screw as it will bear on the outside of the first screw and thus not deform the hex area.
1 Mo thing.....
This thing about the two set screws is good to know and good to remember when trying to disassemble something. Carefully look in the hole to be sure there is no second set screw in there. DAMHIKT
