color for anchorseal?
DizD
Is there a quick and/or easy way to color clear anchorseal? Thought about trans tint dye, but would food coloring work? It is sold in colors in 5 gal buckets, but not sure I'll need this much.
DizD
Re: color for anchorseal?
Food coloring or Rit dye will color the water but I doubt it will color the wax in the emulsion. I think you will need a pigment. But, why are you coloring this stuff? Would make more sense to color the end of the log with Tempra paint and then add the seal.
Don Stephan
You could check with the manufacturer. The product is available in colors I believe.
DizD
It is just an image thing. I'm contracting to work on a legacy tree to be taken down and the end seal will be nearly the only visable thing client will see. Thought it would make job look more professional.
then I would color the end of the tree with anything water soluble or a water dispersable pigment and seal over it. I'm thinking Tempra paint (art supply store or section of hobby store) would work. A thin coat of Milk paint would work but it is pricey.
Diddling with emulsions can be tricky and the sealer is a waxy emulsion in water. I added just 100 parts per million of something to a water based finish (equivalent to an emulsion) and it gelled.
Paint stores will have pigment concentrate that can be added to latex paint. It is possible that this concentrate mixed with the sealer emulsion could add color to the end seal.
Re: Call the manufacturer...
Rick L
Why does everyone seem to rely on forums. I see more bad and incomplete advice on forums overall.
an answer
because 20 years ago most every company had a tech service department that mortals could call and get a knowledgeable person to discuss a problem with. Take Lyman for example, the gun sight company. Used to be you called and got a person. Now you email, enter your question, get a ticket number to track your request for information and days later( it has been 5 so far) you might get an answer.
Does anyone on the forum know the aperture diameter of the target vs hunting peep sight?v Does anyone know a forum where I might get an answer?
Re: The correct answer
Rick L
is that they sell it in colors.
http://www.uccoatings.com/Products/Anchorseal Scroll down to the color wheel. And you cannot use food coloring and other tints on anchorseal because it's a mixture of wax, oil and water. They will sell you the pigment that they use.
http://www.highlandwoodworking.com/tints-all-universal-tinting-colorant-1-1-2-oz-tube.aspx
These might work as they are supposed to work on waxes, oil and water based finishes.
BTW, this info was given to me with a quick phone call to the manufacturer which took less than two minutes. I've been doing research for 45 years like this and the web just makes it that much faster. Instead of asking on a forum I just look up the answer direct. I asked a question when I first used the web twenty years ago and the answers were so stupid I learned how to search and haven't asked a question on the web since then. Having been in the business 45 years I have experts in all fields I can inquire with.
Re: an answer *LINK*
Galen Vetterick
Bill:
Contact the tech support at Brownells here in Iowa. You can talk to someone on the phone. You are going to need to have the make and model of the gun and if you are intending to shoot short range or long range. They can probably tell you if you will need to change the front sight as well.
http://www.brownells.com
thanks
