A problem sanding won't fix
Shown is the top for a desk. The wood is rift, curly ash and the string border is African Blackwood. Now suppose one wanted to stain the ash black. Fine black particles would be added, they would lodge in the ash pores and at least the pores would be black. See the problem? Note the black lodged in the pores above the string border in picture two. I think (hope)these particles will blow out.
I put a coat of shellac on the top before leveling the string inlay with the idea that the shellac would partially fill the pores, or at least make them less attractive for lodging black particles. Sanding was out of the question. The fine particles turned the ash black. So, the top was scraped with a scraper. The particles generated by the scraper tended to be fibrous and didn't stick in the pores tenaciously.
If anyone has other solutions to dealing with a black inlay on light wood I would like to know. The marquetry folks must face this problem all the time.
Re: A problem sanding won't fix
pecker
I once made a curly maple jewelry box lid with black inlay.
After cutting the recess for the inlay I completely finished the maple, with an amber dye and 3 coats of lacquer.
After installing the inlay I carefully sanded it with a block until I was just grazing the lacquer. Then I gave the entire surface a very fine sanding all over, wiped it clean, and applied one more coat of lacquer to the entire lid.
The black epoxy never got down into the pores this way.
del schisler
cant use air hose with lot's of preasure and try and blow the dust out, of course it won't work if any finish is aplied ? good luck
Keith Newton
You probably should have used a paste grain filler, sanded and sealed, before doing the inlay.
The heat from the sanding, may have caused some bonding with the soft shellac, so if it doesn't come out by blowing, maybe try flooding it with alcohol, working it with a brush, then air pressure.
Also, one of my air nozzles, has a hose barb for a siphon tube. Sometimes I use it to pick up a finishing drip from an otherwise perfect wet surface. You could try using that to suck the flooded pores, without the fire risk of using a shop-vac.
And then if all that fails, you might try using the past grain filler over what is left. That would at least hide any that didn't get exposed along the side of each pore.
It has been so long since I actually had to deal with this, I'm not sure how I actually did what I did.
Dick Coers
A stiff nylon scrub brush with air blast will help.
Not OT, Actually *LINK*
You might try skin pore cleaners that are designed to remove oil and stuff from enlarged skin pores. You will need to moisten the surface with water, put on the strip and rub for full contact, allow to set up, then peel off. Wood grain will raise a bit, but go back to your card scraper.
Find'em at the drug store.
As usual, test on firewood first.
pore cleaner
Alternative
You can also try the "peel-off" paint stripper and sets up as flexible sheet. Don't know if it would leave a different kind of deposit, however. test-test-test ;)
clarification of the question
The question is generic. How does one work on a surface with contrasting wood color, in this case a porous light colored wood with dark inlay, without contaminating the light porous wood? Again, the marquetry folks must have solved this problem and the situation, while not common, can crop up in modern furniture design.
I dealt with the issue by partially filling the pores with shellac and scraping, notsanding. I am fairly sure the stringy shavings from scraping will largely blow out. I am wondering if there are better solutions.
Jesse Cloud
I use a process pretty similar to pecker's. A few coats of shellac or lacquer to seal everything, then I cut the inlay grooves (fully expecting a little roughing up of the lacquer), install the inlay just barely proud of the workpiece, scrape flush, blow off with air, scuff sand, then more coats of lacquer.
With marquetry, the veneers are so thin that there is very little sanding and hence very little dust, so this is typically not a big problem.
marquetry page info *LINK*
Dick Coers
The picture must now be levelled to a smooth flat surface with a cabinet scraper. Abrasive papers should not be used at this time as the sanding dust will clog the pores of open-grained veneers.
http://www.marquetrysociety.ca/Finishing.html
Bill Been there done that in the turning world. You have to seal the wood between every grit. Blow it out with an air compressor between every grit as well. I screwed up and used Padauk with Ash which is worse. Using the technique above I was able to keep it to a minimum. I've very good success with woods that don't stain as bad as Padauk.
thanks for the tip
what do turners use for sealing?
