OT Old eyes Question....
Am I the only one who finds the new LED traffic lights to be almost blinding at night? Especially the green light and when its wet or raining? My impulse is to creep through the intersection and to hold my red tipped cane out the window and wave it back and forth in front of the car.
Re: OT Old eyes Question....
Not there yet,,,
Keith Newton
But, facing other challenges. I'm down at the cabin for the weekend, alone. Last night, I got up to go the the bathroom, put my glasses on, and one lens fell out. The little screw, about 1/8" long, had backed out, but was still in the upper hole.
I managed to get over the kitchen table with everything to try putting it back together by braille, which was quite a challenge for stubby, my 3/4 thumb. My uppers, are +3.75, which is a lot stronger than most people can use for their reading glasses, so everything is really fuzzy without them.
I fooled with them for about 15 minutes, trying to turn the screw with my pocket knife, before it dawned on me to try finding the glasses kit, while pinching the frame together with my hand. After finding a good driver, it only took about 5 minutes more to get them back together.
It made me realize that I need to keep a back-up pair in my truck. Glad I don't have to drive the 2 hours home without them.
Bill Howatt
I hadn't noticed it but I'm not surprised that the green is worse than the red for you since the eye is much more sensitive to green than red. I read somewhere that if they could do it over again red would not be used for "stop/danger". Longer-wavelength red is also harder to see without glasses if ypu need reading glasses. I recall cursing a rental car (GM) at night that had a red numeral dashboard which was the poorest color they could have used for focus.
I'll try to remember to pay some attention to your problem the next rainy night I'm in the city. Out where I am traffic lights aren't all that plentiful.
Bill
Mom told me . . .
steve mackay
Last winter, up North, my Mom said there was another problem with them . . . when the temp was down for a couple days, because they don't generate any heat, the snow made them un-seeable. Many, many "accidents" due to poor visability and un-readable traffic lights. Now, after spening un-told amounts of money to replace with "green" traffic lights, they are trying to figure out how to spend even more to protect against snow build-up. Some sort of "heaters" are the option. So much for "green". The whole shebang should cost twice the money and energy that the old lights did.
Re: Mom told me . . .
I heard New York City Replaced their with the LED versions and had the same problem. They turning into big balls of ice and snow in winter. Went back and installed heaters. I wonder if they turn the heaters off in summer or mild weather? Your tax dollars at work. They tried to save energy and justified the outrageous expense by claiming it would reduce maintenance because LED's last a very long time and it would cut the cost of replacing bulbs. (IE take money out of the pockets of maintenance workers.) I wonder if the heaters will up the maintenance. Perhaps the thermostats if any will require a little tuning.
I wish they would put dusk to dawn sensors and turn them down a bit at night.
Maybe they could put both types of bulbs in them and have a summer winter switch.
Cataracts
Over the past few years, I've noticed that oncoming headlights and streetlights look like sparklers. My eye doctor told me it was because of cataracts. You might want to get checked for those.
Re: Cataracts
Joseph Mulherin, sr
Yes, Ellis, I, to, have this problem and have an appt in Oct to see about surgery.at my local VA hospital....damn it is bad to be getting old....and I am 79 right now, but still active
Re: Cataracts
Kevin French
I have the night stars also but it's a side effect of Lasiks surgery.
Another of those words that changes meaning
Remember when we were young, and cataracts were small waterfalls, really interesting to hike to?
Sigh
Re: ...bad to be getting old...
Jerry Nicholson
but the alternative is worse!
Jerry (Only 77)
So the best solution may depend on region
snow buildup's not a big issue in our town, so LED traffic lights might well be just fine.
Kurt
Maybe put a moisture/temperature sensor in the top of the case? For example, temperature below 35 or 40 degrees and moisture present, turn the heater on.
Dale Lenz
Thank goodness...
Dale Lenz
for catract surgery. Had blurred vision 4 years ago, 57 yrs. old. Look mom, no glasses or contacts. So happy that modern medicine could fix my vision problems!
Not really sure, kind of looking forward to the eternal life. BUT, since it is a one way trip for all but Jesus, guess I will wait. (I'm 72 - hoping for a few more years here!)
Joseph Mulherin, sr
Agree, :arry, I am 70 but still active. I do not use my saw anymore because of the fear of cutting my fingers due to this darn cataract situation. My next appt is at my local VA in Loma linda, Ca to see about the surgery in Oct.
Joseph Mulherin, sr
Hi Larry, I want to mention that I used to live in Lafayette for 25yrs. Went to the catholic school
on Brown St. , then went to Jefferson High( understand that it has been turned into an apartment of sort facility for seniors GO BRONCOS
I get over to Lafayette about once a month. I was born in the northern part of the state - Roselawn. Did live in Lafayette back in the early 1960's for about a year - lived in the YMCA - was laid off my job and moved their to work at Kirby Risk in the motor repair shop. Also had a night job at Swatz Shell Service. Loooong time ago!
Joseph Mulherin, sr
Yes, Larry, I remember those businesses. After my Navy inlostment was up I went into the {lumbers/Pipefitters Union #240 and served my 5yr apprenticeship. Was drawing journerman's wages in my 3rd yrs. Went outside the union and went 3yrs to a class for a refrigeration college degree....passed the course, got the degree but no work thru the union....and I finally moved out here to Indio, Ca and had a spinal operation by a doctor my Mom wanted me to see. Then we just settled ...got stuck in the sand dunes i guess....LOL. Spent 2yrs going to a junior college, got AA in acctng, spent 4yrs doing office work in acctng; got discussed with one employer and went back to construction before retirement in 1991 from construction work. Am now an old man retired totally and trying to stay into the woodworking area that my mind benefits from from time to time and projects to projects. In the fall we intend on replacing the board/stucco fence between our yards, pool fencing, Nothing else going on except my visits to my VA occasionally.
