OT: Cutting Precise Drywall Strips
John McGaw
For various reasons that aren't important to the question, I've decided that the best way out of my gallery/library project ceiling is to make it into a very subtle tray ceiling. Part of it is easy like cutting rigid foam insulation and gluing it up to act as a spacer. I cut the 7X96" foam strips using my table saw and it was a snap. Now it comes down to cutting equal size strips of drywall and doing so very cleanly and precisely but my typical drywall cutting is anything but clean and precise. Does anybody have an idea how a duffer might cut 1-1/2 sheets of drywall into 7" strips with clean edges?
Re: OT: Cutting Precise Drywall Strips
This will be interesting. "Precise" and drywall are pretty much mutually exclusive.
You can cut it with a razor knife and a straightedge. The pro's cut one side, snap or fold it and then cut the other side. This should give you a relatively straight and clean edge. You an buy a drywall rasp and clean up the edges further. Any big box store or drywall supply place with have them. A cross between a block plane and a cheese grater.
Generally, we cut it slightly undersized and install corner beads to make the edges square and crisp. Again, square being a relative term.
You can cut it with a saw (table saw, circular saw, whatever), but if I were cutting it on a saw I would want to use somebody else's saw. Think nasty snowstorm. Not only is it nasty to saw, it dulls saws. We cut it with a multitool on the job. Does a wonderful job, but eats up blades. I save them and file them with a diamond file. They end up pretty raged, but cut drywall like crazy.
RobCarr
Power saws make a dusty mess of things. You're best bet is going to be use a "T-square" straight edge, score both sides of the drywall with a *sharp* utility knife and then snap it off... that's about the best you going to get.
Neal in San Jose
I've put up several acres of drywall, and would try to not cut it at all. Sheetrock can be "encouraged" to bend. If you can make up a quick and dirty mold or form, you spray the wrong side of the sheetrock, add some weight and slowly (like overnight) it will sag into the form. I've done similar things for barrel ceilings and a few other curves. I've even just clamped one end of a long piece to a sawhorse, letting the other end hang out like a diving board, sprayed it with water and in the morning the strip was a gentle curve with the loose end touching the floor.
Tom
I'm not exactly sure what you are after, but I have made certain plaster deals with foam alone. I just cut the foam, then skim coated it with plaster. I used edge molding and tape to ensure against cracks. I mix modest amounts of acryli bond into the plaster, it doesn't take much, and I haven't had any bonding problems. Works great.
basil
Jig saw and a straight edge maybe?
I would try plaster too...
John in NM
Only I would use washer head roofing nails (like about 5-6 inch ones) to hold wire lathe to the foam and then plaster over it with Structo-lite followed by a coat of Red Top. Or in a pinch, you could use hot mud, they sell that most everywhere.
I mix vermiculite into plaster since we do a lot of straw bale walls and often have big voids to fill. Helps give the plaster a lot of pluck without making it too stiff. It too may not be available everywhere though, I'm lucky to have a supplier in Albuquerque - they use it to make fire proofing compounds for structural steel. Sometimes you can find it at a garden center.
I'm with Barry
Utility knife, block-plane-sized Surform or similar tool. You can get saw guides that will assemble up to a bit over eight feet, if you want a straightedge.l
I'm not clear if you're laying it up in a long curve, or doing 7" strips between beams. If that latter, I'm also with Barry that you might consider cutting a tad undersized, then use J-channel edging on it. You can push the edging up against the beam while installing, then feather it out with mud to make it disappear.
If you're doing a long curve, never mind about the edging. In that case, I think NM John's got the right idea.
Regardless, consider air blocking. If you haven't already, you should use spray foam between your insulation to block airflow.
John McGaw
I guess I wasn't clear enough. My task is to put up straight narrow strips of drywall around the perimeter of a ceiling. The thickness and width are predetermined by an existing small soffit which covers water pipes the length of the house to the kitchen. My intent is to blend into this preexisting soffit and add a bit of interest to the wall-to-ceiling transition. I want the cleanest possible edge so that I can finish the exposed 1" edge without a lot of work or the use of molding which would complicate things. The perimeter of the room is 80 feet so there is a lot of edge to fix up if I don't do a really neat job in the first place. Makes me wish I could afford to hire a pro since I really hate drywall work.
Thanks for the additional info. I was scrambling to figure out where this turned into bending drywall. Was wondering if Tray Ceiling meant different things in different parts of the county.
Years ago I made a dining room with a tray ceiling because I had to have a duct run down one side of the room and rather than have the room be asymmetrical, i boxed in all the way around. In the center of the room I recessed the light fixture base up between the joists. Liked it so well I put it in a number of houses whether they needed it or not.
I am gathering that you want to make the lower corner of your boxing a nice clean straight edge. (?) If so, what you do is cut the strips for the faces of the box with a knife as I described, shooting for them to be about a 1/4" under sized. Install them so that they are flush with the corner or slightly recessed. The key here is to have your beam or framing you are attaching to as straight as possible. Use a string or other straight edge to get the framing straight. If you need to you can shim the drywall out. You can have a small rabbet on the corner but nothing projecting beyond the adjacent surface. At this stage, you apply corner bead. The old school type is made of perforated and textured metal. The newer stuff has a metal angle in the corner but has the equivalent of paper tape on it. You apply a thin but liberal coat of mud down both side of the box, press the corner bead into place and carefully adjust it to "sit" on the corner. Using a drywall knife you firmly press the tape into the mud (mud being drywall compound). Once you like the position, leave it alone and come back the next day for a second coat. (and then a third coat, etc.)
If your corner is not a ninety degree corner, you can buy flexible tape. The version I am thinking of has two thin metal strips attached to paper tape. When flat, it can be rolled up and in fact comes rolled up in a box. Unroll it, cut the length you need, fold it to the angle you need and it becomes considerably more rigid and bed it in mud. You can make out side or inside corners with it. Does a surprisingly nice job of "cleaning up" the corners.
You mentioned 80 feet. Regular corner beads comes in 8 or 10' lengths in the borgs. Have not checked to see if longer lengths are available. The rolled stuff comes in something like fifty or maybe hundred foot lengths. Its not hard to piece the rigid stuff, so I would go that way. It would be tedious to install a very long length of the flexible stuff by yourself, I think.
You should practice this on somebody else's house. Somebody you don't really like and does not live in the neighborhood. (Frank Lloyd Wright said young architects should start their practice far from home because the only thing an unhappy client can do is plant vines.)
I advise that you take a minimalist approach to this. Put the least amount of mud on the wall that will reliable do the job. Bed the tape and corner beads in a thin layer and let it dry. Apply another thin coat, building thickness slowly, and let it dry. On bulges like butt seams, think of a joint that is two feet wide and 1/8" thick rather than a quick and dirty one that is eight inches wide and a 1/4" thick. Buy decent flexible knives. Buy ones ranging from four inches wide up to about ten inches or more. With each successive coat, step up to a wider knife. Use a tray or hawk to hold the mud and keep it clean. Wet the mud a little and let it slake for a few minutes. You Tube might be your friend here. The pro's can coat a corner bead in not more than three applications, I suggest you try for five. Less mud, little or no sanding between coats, patience. The first coat including installing the beads will take hours. The second coat, less than half the time. The third, half of that, and so on. At the end, use a raking light.
Incidentally, the corner beads project about a 1/16" beyond the corner. That give you a "hollow" for the mud.
Have I missed the question again?
Corner bead...
John in NM
That is exactly what it is for :D
Ps....The trick is....
to cut the strips undersized. Don't fight for precision. Cut them a 1/4 or even a half" too narrow and put them up. Mud is your friend. Filling a 1/4" void on either side is easy and cheap. Also, use glue and screws rather than nails. Pounding on the nails tends to rattle the adjacent pieces and shake the nails loose.
Phil
I'd give the Fein Mulimaster equipped with a round diamond blade a try. I'd use a 1 x as a straight edge, and hook up the shop vac for minimal dust. I have done this with plaster, but never tried it with sheetrock.
Re: Ps....The trick is....
John McGaw
Thanks. I've already got a box of the flexible corner tape with the metal strips from a previous project so I'll probably try that first. The longest continuous run I need to make is 16' since the 24' dimension of the room is broken by a boxed-in beam. The foam which is acting as spacer and backing is glued up and I was planning on gluing and screwing the drywall over that -- I hate nailing drywall under the best of conditions.
Does it have to be drywall?
Gary Smyth
Why couldn't you use wood? I have seen some pretty effective looking "plaster" that was wood with a skim coat and painted. For a ceiling where it won't experience handling and with the requirement for straightness with a max 16 foot length, a test might be worthwhile. You wouldn't even need 4S lumber just a good edge. Set the wood and then if you need bead or tape apply it to wood that already has a hard edge. I understand that this is pure speculation, but if it passes no one but you will know and the installation might be a lot less labor intensive. Just a thought to solve a problem..
Maybe, instead of drywall,
Keith Newton
You should use MDF instead. After it is up, you can treat it as if it was gypsum, but maybe a little caulk is all you will need.
The time savings is worth a higher material cost.
waroland
Makita makes a battery powered saw, SH01W 12V max Lithium-Ion Cordless 3-3/8-Inch Circular Saw. We use it for drywall all the time, usually when we need to cut off small pieces. It cuts straight if you can. We use a Rockwell RW9229 VersaCut 3-3/8-inch 44T HSS Circular Saw Blade.
Jason Roehl in Lafayette, IN
I second this.
Pre-primed MDF will definitely save you some hair. Nail it up (or screw it), then fill/sand the nail/screw holes, then caulk all the seams (sand flush first) and corners. An afternoon instead of a multi-day process.
What you're describing with drywall would not be much of a challenge for a pro, but I've slung plenty of mud and would not want to do that.
Flat paint will be your friend in the end.
Jason
Tom
My thought is that you sound like you are trying to make drywall do something it is not well suited to, as you know. It doesn't like to be cut accurately, by normal means, and whatever it looks like at that point is a far cry from what it will look like when it is all taped and such. One of my rules as a home handi man is to use plastering techniques when the number of joints in drywall exceeds a certain amount. The results are normally better and usually there is less dust, and it is cheaper, and more fun. In this case, still not perfectly clear what you are doing, but I would probably do a plaster screed. I did this once for a boat keel using epoxy. It's a simple process, erect some guide strips. get the right mix. Apply and scrape off. Gives very clean results.
