A55 Smoothing Plane
Delta DL-40 lathe...HELP
Janice Manuel
I posted this on the turning board, but since it's more a general machinery question, I'm reposting it here...
Help.....my lathe that I use almost daily quit working....started having trouble with it dropping speed a couple weeks ago, and it quit yesterday. A google search turned up some info..mostly that my now 20 yr old machine had issues with it's electronic speed control system. Does anyone have a schematic for the main control board? From what I read, Delta has no replacement parts available for this machine anymore...
Worst case is we have to replace the motor and controller...currently, it has a 1.25 hp DC motor which has always been enough for me. I'm a spindle turner...Any suggestions as to what to replace it with? I have someone who can do the repair...I am not sure yet if the motor is going bad, or just the controller....
I don't want a new lathe...I need this one working...
Re: Delta DL-40 lathe...HELP
Larry in nw ohio
Janice Try going to www.vintagemachinery.org and they probably can help. They might have a parts manual. Good Luck. Larry
del schisler
did you go here and is that the full model number ?
http://www.ereplacementparts.com/search_result.php?q=Delta%20DL-40%20lathe&show_only=models&results_per_page=100
del schisler
i also did a google search also just copy and past
http://www.google.com/#sclient=psy-ab&q=delta+dl+40+wood+lathe&oq=delta+dl40+&gs_l=hp.1.1.0i10l2j0i22i30j0i22i10i30.1215.33024.0.36938.120.48.0.0.0.29.340.10076.0j3j30j7.40.0...0.5...1c.1.17.psy-ab.ERyK4aTfS8M&pbx=1&bav=on.2,or.&bvm=bv.47883778,d.dmg&fp=a224560faaf1953d&biw=990&bih=544
del schisler
some info http://vintagemachinery.org/pubs/detail.aspx?id=5676
here is a break down of your machind
del schisler
this is the model number here is thw brake down of your machine sorry for lot's of post's
http://www.ereplacementparts.com/delta-46400-type-1634-wood-lathe-parts-c-3275_9659_12797.html
Re: here is a break down of your machind
Janice Manuel
I have all the original documentation that came with that lathe...
There is no schematic for the actual circuit board in the speed control unit.
Next question is.....and I am going out to ask locally in a bit...if we choose to replace the current motor/speed control, does anyone have suggestions as to what to get?
one of the google search had info on replacment.
Possible variable speed motor choice *LINK*
Jerry Nicholson
If you had to replace your motor and controller (I think a controller failure is more likely than a motor failure) Penn State Industries has a variable speed motor kit. I have not used this unit and have not seen on in person so I can't tell you anything about its quality and adaptability. I have thought about getting one for my el-cheapo Harbor Freight lathe and my drill press but I have not gone beyond the thinking stage. Variable speed would be nice on my little metal working lathe too.
Jerry
Penn State Variable Speed Motor Kit
