cutting black pipe for clamps
Brad Bransky
Before I ruin a hack saw blade, I thought I'd check with you all for advice. Black pipe for Pony clamps can be bought cheaply in ten foot lengths. Can they be cut with a hack saw?
Incidentally, a few weeks ago I asked what causes edge snipe at the end of a cut on the jointer. I got some good answers and advice. I discovered the culprit is too much hand pressure on the rear end of the board as it crosses the blades. If I keep my hand well in front of the right end of the board I get no snipe. So thanks to which of you suggested same.
Brad
Re: cutting black pipe for clamps
Jack Guzman from Maine
Yes
Black pipe cuts easily with a hack saw or pipe cutter(my preference).Or if I'm in a hurry I'll use a sawzall with a fine tooth blade.---Jack
Yes, but...
John in NM
Hacksaw will cut just fine. You might find the project a bit tiring though, if you have many clamps to make.
I bought various lengths at Home Despot to keep the threaded ends. You can make a 10' clamp the from two 5' pipes for the one and only time you need it :D I never compared prices, but given the razor thin margin at such stores, I would not expect there to be a huge difference by the foot.
I also used the pipes for a photo backdrop frame, back when I made and sold stuff large enough to require such a frame. As a result, I have 4 1' sections that get used as much as F clamps - they are amazingly handy with Pony clamps on them.
Ralph Lipeles
You can cut it with a hacksaw but it would be better if you had a pipe cutter. The hacksaw can cut askew, making it more difficult to start the threading die. The pipe cutter rotates, so it makes a nice square ended cut.
Ralph Lipeles
Mike Mills
mike mills
IF I were going to cut them I would use my angle grinder with a cut off blade.
That said, I would buy shorter lengths (maybe 3'-4') and use couplers as suggested when longer ones are needed. The pony clamps should come with two rings which screw onto the threads to keep the clamps from sliding off (thet look 'bout like a keychain ring). If you cut the pipe you will have to cut it straight and then need a die/pipe threader to cut new threads on the cut end.
Brad Bransky
Thanks for the suggestions.
I tried a hack saw and wore off teeth when only about 1/16" in. Plus, it's too much work.
I tired a cold chisel and mallet but couldn't keep a straight line.
I'll try a metal blade on my recip. saw.
Westlake Hdwr. here in Lawrence sells Sched. 40 3/4" 10ft. black pipe for $15.99. I paid $9.97 for 36" at Home Depot.
Do you have a way to cut threads?
Gary Smyth
Pony clamps have to have a Acme threaded end and both ends if they are to be linked to one another. All my Pony pipe connectors are for 1/2 inch pipe and none have a press fit on the clamping screw end. Are the 10 footers already threaded?
Ask if the seller will thread the cut ends for you at no cost.
Plumber
Do you know a plumber? Most of them own pipe cutters and threaders. It's a quick and simple operation if you have the tools.Home depot around here has a threader in the plumbing aisle and will cut and thread pipe for you.---Jack
No cost or cheap
Our local hardware store charges so little for threading that, if their threading dies weren't worn out, there'd be no rational reason to thread my own.
NPT thread on pipe
Dick Coers
"Pony clamps have to have a Acme threaded end and both ends"
They do not. The thread on the clamp rod is Acme, the thread on the pipe is standard pipe thread.
You need to buy better blades...
Dick Coers
if teeth wear off on black pipe. It's a false economy to buy cheap hacksaw blades because you spend so much energy to use them. And you use too many of them to do the job. Buy some good bimetal blades and the cutting will go quickly. BUT, as mentioned, rent a pipe cutter if you don't have one.
I know better. You're correct. NPT for pipe
cut off blade for skill saw works much quicker.
If you are getting snipe it is because the outfeed table is too low relative to cutting circle of knives in cutter head. Raise out feed table until it goes away.
Re: Yes, but...
William Duffield
For the one and only time you need the 10' clamp, you may not even need a connector. ;) Turn one clamp around, so the ends with the cranks are at opposite ends of whatever it is you are clamping. Turn one of the sliding ends 90° and hook it over the other sliding end. Take up the slack with the sliding ends, and tighten with one crank or the other.This might not be very useful for a panel you need to make flat, but it's great for squaring up a cabinet.
I've done that too...
John in NM
There is some risk of having the whole thing pop apart and dent the wood. It does work better with pipe clamps than with 5" throat F clamps :D
Re: Good blades..
david weaver
...and sometimes it's not even enough to buy bimetal, some of the bimetal blades are junk.
Lenox bimetal blades are good. The buck bros branded bimetal blades that are sold right next to them at home depot ...I don't know what they're good for. Maybe for cutting aluminum. The first time I cut steel with the buck brothers blades, it failed right away. They are only slightly cheaper than the lenox bimetal blades, but they are not worth a tenth of the price of the lenox.
Re: Plus oil or saw wax
Keith Newton
Brad, if the hacksaw is dulling that quickly, you must be dragging the blade backward. Like files, these blades stay sharp longer if they only contact the metal going forward.
